Author Topic: $50 robot: LED motor status?  (Read 794 times)
Offline Selenaut-14Topic starter
  • Making the $125 robot...
« on: July 04, 2010, 11:58:16 PM »
I feel like I am asking a very stupid question.
  Would adding an LED and appropriate resistor in a correct fashion to the circuit of a servo on the return trip to the microcontroller work so that it would light up when that servo is being used?
  Note that I am using the circuitry for the $50 dollar robot with this mod only... For now... And that I am a complete rookie to this.
PS: hello, I am new around here. While I am good at building the mechanical aspects of robots, I suck at circuitry. So come asking me things about frames and torque and things like that. I am NOT the go-to guy for circuits.
The answer is always yes if it is never no.
SKILLS:
Building- great
Coding/programming- good
circuitry- pitiful
Offline Alfa_Zulu
Re: $50 robot: LED motor status?
« Reply #1 on: July 05, 2010, 06:43:55 AM »
ah, no.
the only communication between the mcu and the servo is through the pulse output which is send to the servo.
the servo + and - go straight to the regulator so no communication, however you could connect an led to another output pin and - (ie using an output from the muc as + and - on the bus) then you could write extra code to tell the mcu to output 5V on this in if this servo is being used, or something along those lines.
you could probably do it another way but this is how I'd do it.  ;D
« Reply #2 on: July 05, 2010, 07:58:46 AM »
Okay. I was going to use it to make sure the motors were working properly.
SKILLS:
Building- great
circuitry- pitiful
« Reply #3 on: July 05, 2010, 11:18:25 AM »
If you use a re-triggerable monoflop (can be made with a 555 or eg. a 4093) and set the period to say 35..40ms and then let it drive the LED, you will have visual indication when there is a signal to the servo.
Problem is, that there is signal to the servo when it's stopped, unless you drop the signal on purpose.
If you only want it to light when there is movement, you could use a small microcontroller to detect signals that are above or below 1.5ms (but I gather it's a bit over your current skill level).
If it's just for checking whether there's signals going to the servo, the re-triggerable monoflop will do.
« Reply #4 on: July 05, 2010, 11:29:10 PM »
Hey, on the subject if dumb questions, can you get the
photovore to follow a laser pointer?
SKILLS:
Building- great
circuitry- pitiful
Offline Alfa_Zulu
« Reply #5 on: July 05, 2010, 11:59:42 PM »
im sure you could with a camera, make it move towards a red dot.
although if your wearing red shorts it may chase after you, rename it to the bull  ;D
Offline Choco_liger
« Reply #6 on: July 06, 2010, 04:29:13 AM »
A photovore follows light.
So if you shine the laser pointer near the CdS cells then, it'll follow it.
I've tried with my flashlight, and it works. It's quite fun to play with.
Offline Alfa_Zulu
« Reply #7 on: July 06, 2010, 04:44:21 AM »
but surely with a laser pointer having such a small beam would be difficult to control it, especially since you could probably only shine light in one of the cells at an instance.
Last post March 27, 2007, 01:39:43 PM
Last post June 05, 2007, 01:12:04 PM
by AZ196F
Last post June 04, 2008, 09:57:05 PM
by brian
Last post February 19, 2010, 07:53:16 PM
by legobot
