Author Topic: help with finding motor + prop combo  (Read 2415 times)
Offline random robotsTopic starter
  • he drives worse than my robot... thats sad
« on: July 06, 2010, 12:32:42 PM »
specs-
has to be able to carry 3/4 of a pound MINIMUM
combo has to be less than $20 ($10 is even better)
please post links if possible
this is a signature.
Offline Selenaut-14
  • Making the $125 robot...
Re: help with finding motor + prop combo
« Reply #1 on: July 06, 2010, 01:11:22 PM »
Making a plane, I presume?
The answer is always yes if it is never no.
SKILLS:
Building- great
Coding/programming- good
circuitry- pitiful
« Reply #2 on: July 06, 2010, 01:15:34 PM »
yup, a uav. but i need special props and motors that can carry a foam glider and breadboard. got any links?
Offline Selenaut-14
« Reply #3 on: July 06, 2010, 01:53:05 PM »
http://www.hobbycity.com/hobbycity/store/uh_listCategoriesAndProducts.asp?idCategory=265
http://www.kidwind.org/xcart/home.php?cat=79
for the first, you may find something there. For the second, I used it a while back. You'll need the generators and the power output kit (the black fan incthere is what you need.) the generators are actually just motors. Hook up a 9V and I think you might be good to go. However, the 9V might not be enough.
SKILLS:
Building- great
circuitry- pitiful
« Reply #4 on: July 06, 2010, 02:23:27 PM »
thanks. but i want to figure out lift specs to. any places where i can get that?
Offline Selenaut-14
« Reply #5 on: July 06, 2010, 02:32:18 PM »
Not so sure... I still have the set if you want me to try it.
SKILLS:
Building- great
circuitry- pitiful
« Reply #6 on: July 06, 2010, 02:38:27 PM »
I guess you could... but remember if it cant hold 3/4 of a pound up, its gone. unusable.
Offline Selenaut-14
« Reply #7 on: July 06, 2010, 03:28:16 PM »
It's a no-go. Works good as a fan though.
SKILLS:
Building- great
circuitry- pitiful
Offline Razor Concepts
  • Helpful? 53
« Reply #8 on: July 06, 2010, 04:16:51 PM »
The reviews should have some spes on grams of thrust produced.
« Reply #9 on: July 06, 2010, 06:51:46 PM »
not on the ones i saw
  • Helpful? 53
« Reply #10 on: July 06, 2010, 07:12:10 PM »
I meant on the motor pages, usually from the motor page you can read the reviews and find out which ESC and which prop they used to get that many grams of thrust.
« Reply #11 on: July 07, 2010, 05:55:30 AM »
ok, ill try that
« Reply #12 on: July 07, 2010, 06:10:38 AM »
i'm back without any info. any other suggestions?
« Reply #13 on: July 07, 2010, 02:05:04 PM »
new question: should I get a brushed or brushless motor?
Offline Selenaut-14
« Reply #14 on: July 07, 2010, 02:13:28 PM »
It may cost a bit more, but I researched and a brushless motor is way better than brushed... It's just less durable. Your call. Higher efficiency, or higher durability?
SKILLS:
Building- great
circuitry- pitiful
« Reply #15 on: July 07, 2010, 02:17:55 PM »
what do you mean by efficiency? lower required voltage/current, or better rpm?
« Last Edit: July 07, 2010, 02:57:20 PM by random robots »
Offline dunk
« Reply #17 on: July 07, 2010, 04:35:18 PM »
have you considered asking this in a Radio Control forum rather than a Robotics forum?
the first sticky on RCgroups.com "Aircraft - Electric - General" section http://www.rcgroups.com/forums/showthread.php?t=966298
tells you about the awesome http://www.flybrushless.com/
FlyBrushless.com will tell you what force you can expect with a variety of motor/prop combos.
how much force you need to lift 3/4lb in a fixed wing aircraft will depend entirely on what airframe you are using.
