Author Topic: Best sensor for distance/object detection  (Read 2704 times)
Offline philosophyincodeTopic starter
« on: July 06, 2010, 03:30:51 PM »
Hello,
I am wondering what type of sensors would be the best for object avoidance and distance sensing. Is IR still the best or has it fallen to the wayside in the robotics world in terms of robustness?
Thank you
  • Helpful? 84
Re: Best sensor for distance/object detection
« Reply #1 on: July 06, 2010, 06:21:23 PM »
IR is still good and the Sharp IR Distance sensors work well and still seem to be popular for medium to short ranges.
« Reply #2 on: July 07, 2010, 07:09:27 PM »
"Best" depends very much on the objects physical traits, the distances you need to measure and the precision you want/need. There's no sensor that's all round best (well, perhaps a pro LASER scanner, but it's too expensive to be a serious contender in hobby robotics).
The Sharp distance sensors goes up to 5.5m.
(Sharp Comparison Sheet)
This comparison of different rangers (IR and US) doesn't list the above mentioned Sharp sensor and US can be used at a larger range than what's mentioned, but it's informative none the less.
It doesn't mention LASER rangers either (Like used by eg. Bushnells) - rangers, not scanners - which is yet another way to shave that goat, but I think that you'd have to hack a device containing such a beast, as I haven't seen any sold as just the ranger unit alone.
A LASER ranger will obviously be the most precise and able to measure the distance to what's covered by the small LASER dot and at a much larger range - Tank LASERs work on at least up to a few miles (I should have gotten some when the Russian Army had their large "closing sale" way back - seriously high powered IR LASERS, around 40W IIRC - I could have gotten all the cats in the 'hood... In one shot  ;D).
Electronic measuring tapes using a LASER are expensive but works A+.
In comparison, the US measuring tapes are just bareable on a good day, if you have a large bare wall in an empty room, don't need too high a precision (i.e. a bit better than eyeballing it) and don't breathe too heavy, but in a furnished room... Pure Monte Carlo (at least that goes for the units I own and others I have tried).
In summation: Select your sensor after your targets size, shape and range.
Offline ballbreaker
« Reply #3 on: July 09, 2010, 04:17:55 PM »
IR rangefinder is good for distance detection but because of the narrow lens it can't detect small or thin objects like       chair legs  very good. another good sensor is a sonar it can detect small objects but i don't thing it can measure distance very good at least the cheap ones you could try combining them for better results.
For Those About To Rock, We Salute You!
Last post April 30, 2006, 05:17:27 PM
Last post July 29, 2007, 03:01:32 PM
by Steve Joblin
Last post February 20, 2010, 09:17:21 AM
Last post January 26, 2013, 08:08:42 AM
by waltr
