Author Topic: microcontroller for robotic arm  (Read 3744 times)
Offline dmehlingTopic starter
« on: May 22, 2007, 02:44:52 PM »
I am trying to determine the best kind of microcontroller system for my proposed robotic arm.  Technically, it is not fully robotic since in my present application I intend for it to be controlled by external input through a switch.  It is a very simple design with only 2 degrees of freedom.  Would the Cerebellum microcontroller be suitable for this design or is it more complicated than I would need.
Offline hazzer123
Re: microcontroller for robotic arm
« Reply #1 on: May 22, 2007, 03:38:37 PM »
I am currently designing a robot arm and its controller using a PIC16F628A.
All that the microcontroller does, is accept bytes from my computer via a serial interface, and outputs PWM signals to the servos based on the bytes received. The actual positioning of the arm is calculated by the computer. Therefore a powerful processor isnt needed to do the inverse kinematics etc.
www.icrobotics.co.uk
« Reply #2 on: May 22, 2007, 07:25:02 PM »
Its no longer sold :-\
Your given specs can be handled by almost every microcontroller out there. Just find what you think would be simple and easy to learn and you should be fine :)
Here are the more popular ones:
http://www.societyofrobots.com/robot_parts_list_microcontrollers.shtml
