Author Topic: Will the Axon or AxonII serve my purpose?  (Read 643 times)
Offline craigjTopic starter
« on: July 09, 2010, 09:05:38 AM »
I am an engineering student and as a project I plan on building a master-slave robot arm. For this I will be using say around 10 servos and 10 8 bit ADCs and so am guessing will need quite a few I/O pins. Will the axon or the axonII be sufficient or will I have to use multiple MCUs?
Thanks.
Offline Alfa_Zulu
Re: Will the Axon or AxonII serve my purpose?
« Reply #1 on: July 09, 2010, 09:44:40 AM »
unless you need more then 50+ I/O pins you'll be fine with an Axon
  • Helpful? 107
« Reply #2 on: July 09, 2010, 03:40:29 PM »
Would suggest the Axon II, rather than the Axon, as more of the PWM pins are available which are good for controlling servos.
Another SoR member has used it, along with WebbotLib, to control around 24 servos http://www.societyofrobots.com/robotforum/index.php?topic=11333.0 - and it comes with 16 ADC channels(+more stuff)
Last post February 24, 2009, 10:56:32 AM
by superchiku
Last post July 03, 2009, 07:28:18 AM
by jamort
Last post January 23, 2010, 08:36:12 AM
by Pierre
Last post October 01, 2010, 10:02:32 AM
by PAL Robotics
