Author Topic: connect CMOS output to a differential input or photocoupler input  (Read 1017 times)
Offline minivanTopic starter
Hello all,
I have a PWM output 100mA, 50 Ohm from a CMOS driver. I want to connect it to the pulse input of a input/output card of a PLC. The pulse inputs are differential input (5V) and photocoupler input (5V). Any suggestion on how I should connect them? The pulse inputs to the PLC require 3 wires: pulse -, pule + and pulse input ground. The PWM output is a BNC female connector.
Thank you for your help.
Re: connect CMOS output to a differential input or photocoupler input
« Reply #1 on: July 10, 2010, 02:27:14 PM »
If the optocoupler can be used, it will be the easiest, as you'd just need a resistor between them.
Last post October 14, 2008, 10:21:15 AM
by pomprocker
Last post January 12, 2010, 04:59:26 PM
by z.s.tar.gz
Last post September 05, 2010, 06:25:54 PM
by moltrex84
Last post November 13, 2010, 06:18:21 AM
by azy
