Author Topic: Whats the diference between AxonI and AxonII?  (Read 590 times)
Offline ballbreakerTopic starter
« on: July 09, 2010, 04:10:48 PM »
Do you use them in different situations or AxonII is an upgrade?
For Those About To Rock, We Salute You!
Offline Webbot
  • Helpful? 107
Re: Whats the diference between AxonI and AxonII?
« Reply #1 on: July 09, 2010, 07:19:35 PM »
Axon II has the LED segment display but the main thing is that it has more of the 'high function' pins such as PWM available for your use.
If you've got the WebbotLib download then look in the manual and compare 'sys/Axon.h' with 'sys/Axon2.h' and you can compare and see that the Axon II makes many more of the processors abilities available on the header pins.
« Reply #2 on: July 12, 2010, 07:04:56 AM »
additionally . . .
The Axon II has a more stable power supply, more external interrupts, and the ability to use two separate power sources.
If you plan to have a lot of servos or a lot of Sharp IR, I recommend the Axon II.
Last post April 05, 2007, 07:01:22 AM
by sotu
Last post May 02, 2007, 12:42:04 AM
by mpthompson
Last post October 08, 2008, 05:34:45 AM
Last post July 14, 2009, 10:25:09 AM
by Tazdevil
