Author Topic: Adding webbotlib to eclipse  (Read 986 times)
Offline tmoney68Topic starter
« on: July 12, 2010, 11:20:03 PM »
Since I am strictly a linux user, I have decided to play around with Eclipse. I have downloaded the current version and installed the AVR plugin. It seems to work very nicely. My question is how to include webbotlib? Has anyone done this? Its probably an easy solution, but I can't seem to figure it out.
Thanks in advance
Offline Webbot
  • Helpful? 107
Re: Adding webbotlib to eclipse
« Reply #1 on: July 13, 2010, 10:28:36 AM »
Have you read Dunks tutorial at http://www.societyofrobots.com/member_tutorials/node/381
Does that help?
Offline dunk
« Reply #2 on: July 13, 2010, 11:59:15 AM »
Does that help?
that doc does not cover Eclipse.
but it is good background reading.
so presuming you know how to include WebbotLib from the command line it's pretty easy.
in Eclipse, open your project then go
Project -> Properties -> C/C++ Build -> Settings .
then under Tool Settings point to the various WebbotLib directories and the libWebbot-ATMegaXXXX.a file under the relevant sub sections as you would from the command line.
« Reply #3 on: July 13, 2010, 01:34:04 PM »
Thanks, I knew it would be something simple!
Offline Drod
« Reply #4 on: January 26, 2011, 08:07:40 PM »
Hi Dunk! Hi tmoney!
I'm new to all of this (including use Ubuntu for programming AVR's), and I don't know how to include WebbotLib from the command line / Eclipse..  ???
I only achieved to use AVR plugin with Eclipse  :-X
Please, can you make a Step-by-step tuto?
Thanks in advance!
Last post March 10, 2010, 08:51:50 AM
by richiereynolds
Last post February 17, 2010, 01:32:40 PM
by Webbot
Last post August 16, 2012, 11:50:57 PM
by greywanderer012345
Last post December 01, 2012, 10:07:53 AM
by krneki10
