Author Topic: robotic vacuum pump  (Read 2570 times)
Offline dmehlingTopic starter
robotic vacuum pump
« on: May 23, 2007, 02:15:17 PM »
In my robotic design, I was wanting to incorporate a vacuum pump mechanism.  Do you have any idea where I could find a vacuum pump that I could control with a microcontroller?
Re: robotic vacuum pump
« Reply #1 on: May 30, 2007, 07:05:46 AM »
http://www.google.com/search?q=%22vacuum+pump%22&ie=utf-8&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a
You will need to hack the on/off switch . . . replace it with a MOSFET, where the gate pin is connected to a digital output of a microcontroller.
Offline drcrash
« Reply #2 on: July 16, 2007, 03:23:48 PM »
Doug Walsh is selling some nice Thomas oilless piston pumps right now for under $100, shipped, at www.build-stuff.com
How much vacuum do you need for what you're doing?  There are several other things you can use as vacuum pumps if you don't need a lot of flow.
« Reply #3 on: July 22, 2007, 02:53:22 PM »
I actually don't need very much suction.  I am using this for a page turning machine, so probably no more than a few inches of static pressure.  I happened to stumble across the robot tutorial for the card shuffling robot which I believe was made by the administrator of this robot forum, and whatever suction pump he used would probably be adequate.
« Reply #4 on: July 22, 2007, 03:32:04 PM »
I just used a suction cup taken off a toy. No air required.
Last post September 04, 2008, 07:12:20 PM
Last post April 03, 2009, 10:33:55 AM
by RiO
Last post August 04, 2010, 03:54:49 PM
by blackbeard
Last post August 06, 2011, 07:43:11 PM
by Gertlex
