Society of Robots
     | Robot Forum | Robot Tutorials | Robot FAQ |
September 10, 2010, 01:02:26 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: SoR Robot Chat every friday night. Join us! (forum integration fix coming when I have time)
http://www.societyofrobots.com/robotforum/chat/
Robot Forum
   Home   Help Search Login Register
Pages: [1]
  Print
Author Topic: Short Tutorial On Dismantling DC Motors  (Read 434 times)
voyager2Topic starter
Robot Overlord
Helpful? 2
Offline Offline
Expert NXT programmer.
View Profile WWW
« on: July 15, 2010, 01:52:49 AM »
So I was getting board today and had a little motor lying around, so I dismantled(say: destroyed) it and wrote a short tutorial of what to do...
TOOLs:
small 1mm screwdriver
motor
time
needle nose pliers(optional, but recommended)
METHOD:
1.Find your victim(motor), mine was a cheap one from a $20 RC car
The victim:
2.Open the motor by bending the two metal tabs(located around the edge of the metal cylinder)away from the plastic "cap" thing with pins sticking out, I used a 1mm flat-head screwdriver.
3.Lever the plastic cap off.
4.Inside there should be a little shaft with electro-magnets(mine had 3).
Step 4 picture:
5.Pull this out with your fingers or the needle nose pliers.
Step 5 picture:
6.The only remaining part should be the permanent magnets these are glued in Angry
7.You have successfully dismantled a DC motor.
You may wish to savage the coil wire, magnets ,etc.
Please +1 my "helpful" tab if this helped you!
« Last Edit: July 16, 2010, 11:47:07 PM by voyager2 » Logged
http://www.youtube.com/watch?v=4buxVyVRRxg
My entry into the 6th SoR robot competition, please watch it for me Smiley
Robot Overlord
Helpful? 2
Offline Offline
View Profile WWW
« Reply #1 on: July 15, 2010, 04:52:01 AM »
Oh and just to amaze you even more:
I put the motor back together(temporarily), and it worked fine, actually better!
I am amazing! Cool
Logged
amando96
Robot Overlord
Helpful? 1
Offline Offline
View Profile
« Reply #2 on: July 15, 2010, 11:01:08 AM »
Try getting better photos, with natural light  Wink
Logged
Rorcle, 60% complete
AATV, 5% complete
Robot Overlord
Helpful? 2
Offline Offline
View Profile WWW
« Reply #3 on: July 15, 2010, 08:43:01 PM »
Yeah,
Mum's camera is amazing in good conditions...
Mine (the last picture)is horrible in all conditions Sad
Logged
Robot Overlord
Helpful? 2
Offline Offline
View Profile WWW
« Reply #4 on: July 16, 2010, 12:07:27 AM »
UPDATE...
I figured out how to remover the permanent magnet,
use a vice/clamp or pliers to squeeze the motors metal body.
The magnets pop out, along with two metal U things that hold them in place.
Logged
Soeren
Supreme Robot
Helpful? 71
Offline Offline
Whatever Works... Works.
View Profile
« Reply #5 on: July 18, 2010, 09:52:47 AM »
Carefull, boards get nailed  Grin
Try using a tripod or similar to avoid blurry pics (Pic #2 from the top is shaken) - shorter shutter times helps too.
Perhaps you're too close for the range of the cam or the setting is out of focus - does the cam has a manual distance setting?
Which cam(s) are you using?
Add lots of light, digicams like that.
This is a couple of handheld shots in less than good lightning:
Logged
>>> Whatever Works... Works <<<
Robot Overlord
Helpful? 2
Offline Offline
View Profile WWW
« Reply #6 on: July 19, 2010, 05:23:41 AM »
I'll take better pictures when I have time, what SoR needs is a tutorial on taking pictures...
Logged
vinito
Full Member
Helpful? 6
Online Online
View Profile
« Reply #7 on: July 19, 2010, 11:54:20 AM »
Would a picture-taking tutorial which includes somehow using an Axon be in the running for an award? Grin
Logged
paulstreats
Supreme Robot
Helpful? 15
Offline Offline
View Profile WWW
« Reply #8 on: July 19, 2010, 05:10:46 PM »
David Cook at robotroom.com has written a piece on closeup / macro zoom photography.
http://www.robotroom.com/Macro-Photography.html
Logged
Pages: [1]
  Print
Jump to:
Subject Started by Replies Views Last post
Motors for the robot in the tutorial
Mechanics and Construction
Arislan 12 5394 Last post October 25, 2006, 10:43:34 PM
by Arislan
$50 Robot sensor short
Electronics
RiffRaff 16 1148 Last post February 27, 2009, 03:37:34 PM
by SmAsH
short amusing robot vid
Robot Videos
Admin 1 627 Last post October 12, 2009, 06:00:43 AM
by Joker94
My SumoBot: Short n' Feisty
Misc
Canabots 6 754 Last post November 26, 2009, 05:11:24 AM
by Canabots
Powered by MySQL Powered by PHP Powered by SMF | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Advertise on this Forum
