Author Topic: Webbotlib Project Designer - Supply Logic  (Read 1152 times)
Offline sasapTopic starter
« on: July 16, 2010, 12:58:27 AM »
Why is the Solarbotics L298 Driver field Supply Logic empty?
Please help.
Re: Webbotlib Project Designer - Supply Logic
« Reply #1 on: July 16, 2010, 09:26:34 AM »
Which board file are you using for your project file? I suspect that you haven't entered in the proper Power Bus voltages.
« Reply #2 on: July 17, 2010, 06:00:28 AM »
The board file is AxonII.
« Reply #3 on: July 17, 2010, 08:26:22 AM »
Its working fine for me . . .
What battery voltage and mAh did you enter when you first created the new project?
Offline Webbot
  • Helpful? 107
« Reply #4 on: July 17, 2010, 09:10:38 AM »
You can view/edit the battery details using the menu option: Edit | Battery Supplies
« Reply #5 on: July 17, 2010, 09:26:15 AM »
I was typed 6 volts and 2000 mAh.
« Reply #6 on: July 17, 2010, 09:29:32 AM »
please attach your file so that Webbot can look at it . . . you must use a zip file for it to upload properly.
« Reply #7 on: July 17, 2010, 09:45:22 AM »
File test.zip
Offline Webbot
  • Helpful? 107
« Reply #8 on: July 17, 2010, 10:13:42 AM »
Your project file works fine for me when adding the Solarbotics L298
However: I am wondering if your version of Java is using a European Locale - ie '.' is the 1000 seperator, and ',' is a decimal point - as that may (?) be upsetting things.
So just in case - I have uploaded a new version which sets it to USA format for the designers.
Can you try again and let me know.
« Reply #9 on: July 17, 2010, 10:43:15 AM »
Itīs working now...
Last post February 08, 2010, 12:23:43 AM
Last post November 14, 2010, 06:54:46 PM
Last post January 11, 2011, 07:26:19 AM
by Webbot
Last post September 05, 2012, 02:46:10 PM
by megaden
