Author Topic: 1Hz Timing Circuit Needed...  (Read 3292 times)
Offline voyager2Topic starter
  • Helpful? 6
  • Behold! The Impossible Triangle of robotics!
« on: July 16, 2010, 10:11:41 PM »
Hi All,
I've been working on my fish lately, and need a 1Hz or 2Hz timing circuit to test the tail with.
I need it to be simple, no ICs, programing, etc.
I have limited time and components.
I first thought of a RC circuit(Resistor Capacitor circuit)but my experience is limited.
All it has to do is swap the polarity of two wires every second(or half second with 2Hz)
I couldn't find anything on SoR, Google, or Yahoo!.
Please help.
Voyager2
« Last Edit: July 16, 2010, 10:27:08 PM by voyager2 »
And it was good.
Offline futmacl
Re: 1Hz Timing Circuit Needed...
« Reply #1 on: July 16, 2010, 10:46:14 PM »
All it has to do is swap the polarity of two wires.
If you search for "LED flasher", you will find quite a few 2-transistor circuits around 1-2 Hz - say:
http://talkingelectronics.com/projects/CircuitTricks/images/LedFlasher.gif
That said, a 555 timer configured for 1 Hz (http://sites.google.com/site/uzzors2k/555Tester_schematic-full.jpg) is actually cheaper and simpler - why the aversion to ICs?
Assuming single supply, switching wire polarity for a motor is actually somewhat tricky. At low frequencies, the easiest option is to use a DPDT relay. For reasonably low currents, you could use a miniature DIP relay that costs about $1:
http://www.allelectronics.com/make-a-store/item/RLY-527/5VDC-DPDT-DIP-RELAY/1.html
This is probably cheaper and easier than building a H-bridge (though H-bridge ICs such as FAN8082 aren't too expensive either).
  • Helpful? 6
« Reply #2 on: July 16, 2010, 10:59:13 PM »
I don't want to wait 2 weeks for ICs and transistors to ship, I need it now!
Does any one know of a good RC circuit.
Parts I have:
ATmega168s x 5
100uF caps rated at 16v x 10
220uF cap rated at 10v x 1
500Kohm pot x 2
1Kohm resistors x 10
LEDs x 40
MOSFET x 1
Bridge Rectifier x 2
And it was good.
  • Helpful? 6
« Reply #3 on: July 17, 2010, 04:19:38 AM »
I'm going to buy one of these:
http://www.sparkfun.com/commerce/product_info.php?products_id=9285
Should help alot!
« Last Edit: July 17, 2010, 04:53:04 AM by voyager2 »
And it was good.
Offline amando96
« Reply #4 on: July 17, 2010, 04:54:53 AM »
Get a cheap wristwatch and use the circuitry inside it.
Rorcle, 60% complete
AATV, 5% complete
  • Helpful? 84
« Reply #5 on: July 17, 2010, 08:00:18 AM »
Write a quick piece of code for the Atmega to toogle an output pin.
« Reply #6 on: July 17, 2010, 05:13:07 PM »
Then a 2 transistor AMV is the simplest solution - transistors can be chosen for the needed current.
  • Helpful? 6
« Reply #7 on: July 19, 2010, 04:36:32 AM »
Wrist-watches are not cheap here in Australia!
Since this is just to test the tail, I don't want to spend $20 on a digital watch.
I'm to lazy to program, that's what I'll do for the finished product.
What is a transistor AMV?
I am a total noob...
And it was good.
Offline Joker94
  • Helpful? 26
« Reply #8 on: July 19, 2010, 05:07:55 AM »
well given what you are saying all you need is a double pole double throw switch. it is really easy, and that is really all you sound like you need.
2 bucks from dick smiths
  • Helpful? 6
« Reply #9 on: July 19, 2010, 05:09:57 AM »
I need it to do do all this by itself, not manually.
And it was good.
« Reply #10 on: July 19, 2010, 05:13:58 AM »
Dude, watch from the reject shop - $2-4.
  • Helpful? 6
« Reply #11 on: July 19, 2010, 05:17:56 AM »
OK I'll try to find one, that is not: massive, barbie printed or pink ::)
And it was good.
« Reply #12 on: July 19, 2010, 05:23:26 AM »
Arduino? Select the arduino pro 8mhz option and you are set. Really easy code
  • Helpful? 6
« Reply #13 on: July 19, 2010, 06:11:12 AM »
I don't have an Arduino, I'm going the squash the $50 robot into it.
And it was good.
« Reply #14 on: July 19, 2010, 07:15:14 AM »
I mean that you have the mega168, so you can run the arduino code on it.
Offline chelmi
« Reply #15 on: July 19, 2010, 10:08:39 AM »
The time you spent looking for an "easier" solution would have been enough to write the necessary code...
« Reply #16 on: July 19, 2010, 04:31:06 PM »
Apparently at using Google as well ;)
Here's a page on Astable MultiVibrators (AMVs) - read it all, you'll learn something.
AMV page
Offline paulstreats
  • Helpful? 20
« Reply #17 on: July 19, 2010, 04:40:53 PM »
Thats a shame, theres a few real time clock IC's that produce a 1 hertz pulse direct from a single pin (usually used to pulse a second symbol/dot on clock LCD's) aswell as the other useful functions like keeping time and pulsing a pin when a preset alarm is triggered.
Offline futmacl
« Reply #18 on: July 19, 2010, 04:45:33 PM »
If you live anywhere near any sort of civilization, it really doesn't take 2 weeks to get two off-the-mill BJTs or a 555 timer.
Also, you really can't avoid stocking these components forever; if you do not have a reasonable library of passive components, transistors, and some of the most popular ICs, you will suffer.
Offline macdad-
« Reply #19 on: July 27, 2010, 12:26:50 PM »
I first thought of a RC circuit(Resistor Capacitor circuit)but my experience is limited....
For future reference:
Formula for RC circuits:
Frequency = 1/(2*pi*R*C)
R - Resistor Value
C - Capacitor Value
Of course you would still need a semiconductor for the oscillation as just a RC circuit by itself is used as a Low/High pass filter which blocks frequencies above or below the Frequency in the above formula all depending upon the wiring of the circuit.
Last post March 09, 2008, 09:48:23 AM
Last post July 26, 2009, 08:37:40 PM
by jamort
Last post April 01, 2010, 04:25:18 AM
by richiereynolds
Last post November 13, 2010, 07:09:51 PM
by artek101
