Join us in Chat. Click link in menu bar to join. Unofficial chat day is every Friday night (US time).
I found a perfect 6v motor in a old RC car, and it's perfect because is small and powerfull for what I want
may i suggest something? http://www.hobbyking.com/hobbyking/store/uh_index.asp it has cheap motors, props, and other things for a uav. here is a link for the products im deciding to buy http://www.hobbycity.com/hobbycity/store/uh_showCart.asp?idproduct=9470&lasturl=/hobbycity/store/uh_viewItem.asp?idProduct=9470. i would suggest buying motors and props instead of using ones found around the house.hope this helps,Patrickedit- can i have the weight of the plane and trust of the motors+props? thanks
As for measuring thrust, you have a scale, so zero out the scale while the motor is on the scale, run the motor and see how much it "weighs" to get the thrust
QuoteAs for measuring thrust, you have a scale, so zero out the scale while the motor is on the scale, run the motor and see how much it "weighs" to get the thrustSo the weight that the scale is showing is the necessary to get the motor off the ground?
...add the motor and prop onto it, weigh it...
