Author Topic: Axon Servo Controller II problem  (Read 705 times)
Offline scottad73Topic starter
« on: July 29, 2010, 10:09:22 PM »
Hello,  I tried to build this project and got the following messages:
Build started 29.7.2010 at 22:07:08
ned-bitfields -fpack-struct -fshort-enums -MD -MP -MT Servo_Controller.o -MF dep/Servo_Controller.o.d  -c  ../Servo_Controller.c
In file included from ../SoR_Utils.h:26,
                 from ../Servo_Controller.c:15:
../global.h:37:1: warning: "F_CPU" redefined
<command-line>: warning: this is the location of the previous definition
../Servo_Controller.c:88: error: 'L' undeclared here (not in a function)
../Servo_Controller.c:88: warning: initialization from incompatible pointer type
../Servo_Controller.c: In function 'main':
../Servo_Controller.c:240: warning: assignment makes integer from pointer without a cast
../Servo_Controller.c:242: warning: assignment makes pointer from integer without a cast
make: *** [Servo_Controller.o] Error 1
Build failed with 1 errors and 31 warnings...
The line that the error corresponds to was:
int *init_servo_port[28]={&L,&PORTL,&PORTL,&PORTL,&PORTL,&PORTL,&PORTL,&PORTL,&PORTG,&PORTG,&PORTH, &PORTB,&PORTB,&PORTB,&PORTB,&PORTH,&PORTH,&PORTH,&PORTH,&PORTE,&PORTE,&PORTE,&PORTE,&PORTE,&PORTG, &PORTA,&PORTA,&PORTA};
I attempted to fix this error but was not successful.  Could you please tell me what I could be doing wrong.
Thank you.
Re: Axon Servo Controller II problem
« Reply #1 on: July 30, 2010, 09:05:38 AM »
Hi
The servo controller code never left alpha version, and is entirely obsolete now. I probably should just delete it . . .
Download WebbotLib and use it with Project Designer to program a servo controller. Its actually pretty easy.
If you get stuck let us know.
Last post February 15, 2009, 01:39:52 PM
by Wizzard
Last post February 20, 2009, 01:13:09 PM
by pomprocker
Last post May 01, 2009, 03:01:38 PM
by dellagd
Last post May 09, 2011, 06:50:02 PM
by Webbot
