Author Topic: Sketch does not run with external power supply  (Read 1445 times)
Offline Warhawk87Topic starter
« on: July 30, 2010, 05:18:09 PM »
Hey guys,
Ive been running all the programs on my arduino duemilanove using usb with no problem, and now that Ive changed over to external power, none of them run.... Whats the issue?
Re: Sketch does not run with external power supply
« Reply #1 on: July 30, 2010, 09:03:10 PM »
Break out a voltmeter and see if power goes to where it must.
« Reply #2 on: July 31, 2010, 12:09:28 AM »
Problem is i dont know where the power must go, and my probes are a little too big 0.o the power light flashes indicating it is getting power, its just not loading the program
« Reply #3 on: July 31, 2010, 05:33:43 AM »
Then you have to find out. Study the schematic.
If you don't know such a basic thing, you have a very little chance of fixing it, so learn learn learn - you cannot rely on a web board for every tiny issue.
Then get, or make, smaller probes - I have yet to see a probe that is too big for even smd though - a point is still a point.
That info should have gone into your first post. It indicates that it get some power, but perhaps not enough, so break out the voltmeter and the schematic. Test thorougly around the regulator.
Offline amando96
« Reply #4 on: July 31, 2010, 06:04:23 AM »
weak battery.
Rorcle, 60% complete
AATV, 5% complete
« Reply #5 on: August 02, 2010, 08:31:25 PM »
Will do soeren... Im just getting started and my first impulse is to run to the web board  ;D
Offline paulstreats
« Reply #6 on: August 03, 2010, 03:01:33 AM »
how many volts are you powering it with, and where are you connecting the power to?
« Reply #7 on: August 03, 2010, 09:06:00 PM »
12 volts, VIN and ground in the "power" pins
