1. - Is it possible to make a functional robot base with only 2 wheels - instead of the standard 2 + caster? It obviously could not climb up any slopes but for flat areas would it be possible?
2. - Whats the best way to mount wheels to bearings then bearing to the base? I have been running into this issue and I am not sure how to solve it. I am also looking to make a tracked bot but I don't want to have to machine all the "track roller things" my self, Does anyone have a good idea on mounting these plastic "track roller things" ( http://www.hobbyengineering.com/H2028.html) to bearings then bearings to the base?
3. Are there any guide lines for designing a 4WD robot that uses skid steering? I am worried about the friction on certain surfaces being so great that it wouldn't be able to turn - do these worries have any merit?
Quote from: Eco19R on May 26, 2007, 12:42:04 PM2. - Whats the best way to mount wheels to bearings then bearing to the base? I have been running into this issue and I am not sure how to solve it. I am also looking to make a tracked bot but I don't want to have to machine all the "track roller things" my self, Does anyone have a good idea on mounting these plastic "track roller things" ( http://www.hobbyengineering.com/H2028.html) to bearings then bearings to the base?my guess would be pillow block bearings, but that depends on size
Instead of using all the track rollers, just use one on each end and place a smooth piece of plastic along the surface that the track is running.
Another idea would be to machine the wheels themselves so the bearing fit inside them and have the axle attach to the base,
Is double sided sticky tape worth using to hold certain parts together?, I have been wondering this and its a bit embarrassing to use it but it seems to fashin mounts for certain things would take too much time.
i really don't get why people always want to use power tools.for making small, straight, accurate cuts in aluminium an old fashioned hand hacksaw is the best tool for the job.
i really don't get why people always want to use power tools.for making small, straight, accurate cuts in aluminium an old fashioned hand hacksaw is the best tool for the job.dunk.
Started by DrGuenter Electronics
Started by unicoder Electronics
Started by spizzak Electronics
Started by galannthegreat Software
