Author Topic: What to do for my robotics arm project  (Read 1382 times)
Offline chrisTopic starter
« on: August 02, 2010, 04:25:19 PM »
hi i just registered to this forum and am new to it, i just wanted to ask that i have an engineering project that i have to do in the university.
the topic given to me was robotic arms.
now im doing mechanical engg. first year in a UK university, but im "totally" new to robotics.
My engineering project module professor explained me that my project should be more about the theory part of a robotic arm and not acctually making a practical model of it.
i wanted to ask now that where exactly do i begin and how do i go about to finish and present my project???
say if it was only to include the theories involved in the robotic arm and not exactly "making " the arm u knw  :( really in a big trouble and really need help on how to go about doing it??
Offline blackbeard
Re: What to do for my robotics arm project
« Reply #1 on: August 02, 2010, 04:35:30 PM »
well maybe if there's supposed to be more theory to this then you can start by such things as the history (the robotr "arm" started in vehicle manufacturing) and work your way up to the modern systems and the controls they use. are you supposed to describe the meat and potatos of how robotic arms function or are you supposed to describe the various kinds and functions?
Next step: Give them vaginas
Offline paulstreats
  • Helpful? 20
« Reply #2 on: August 02, 2010, 04:48:57 PM »
I would imagine that you are supposed to talk about the forces that the lengths of the arm segments have against the joints (fulcrum force etc...). also you probably want to describe about degrees of freedom, and how different tasks would require different degrees of freedom. degrees of freedom can be described as the number of joints and also the directional capabilities of the joints.
 If you want to concentrate on a particular arm, you could describe the human arm. the shoulder is a ball joint with 3 degrees of freedom (all limited to some extent). the elbow is a hinge joint with 1 degree of freedom(also limited). the forearm is capable of rotation (another degree of freedom) which runs off a different system to the elbow and the wrist. the wrist is a dual hinge joint, it moves in 2 directions and has 2 degrees of freedom. convert the joints into mechanical joints and talk about how forces affect the different parts, the limitations of the arm, the good points of it etc...
« Reply #3 on: August 03, 2010, 02:58:21 AM »
yes i am supposed to present the meats and bones of it and not how many kinds are available
like i have to explain the maths involved in it and so on... so where exactly do i start :/
Offline MrWizard
« Reply #4 on: August 03, 2010, 06:13:14 AM »
You could start on the materials that you would be using and why, calculated forces and strength of materials, what is needed, but also about the programming language. I think you would have to seek it more indepth.
Offline amando96
« Reply #5 on: August 03, 2010, 08:15:55 AM »
Haven't read this completely, but it looks like it explains things quite well, SOR's robot arm tutorial
Rorcle, 60% complete
AATV, 5% complete
Offline klims
« Reply #6 on: August 03, 2010, 09:00:07 PM »
Sounds to me like for the math part you will need to explain kinematics of the robot arm, both forward and inverse. I don't think you would be expected to derive the equations for inverse kinematics, but at least be expected to explain how it works.
The general idea is what you can use forward to find the end position of the robot arm given you know the lengths of the joints and the angles, and inverse kinematics gives you the joint angles for a known end position.
Last post May 29, 2007, 05:16:57 PM
Last post January 24, 2010, 10:12:32 PM
by z.s.tar.gz
Last post October 27, 2010, 07:54:34 PM
by aruna1
Last post October 21, 2011, 08:45:02 PM
