Author Topic: radio question. robot combat and a434 transmitters and recievers  (Read 1888 times)
Offline blackbeardTopic starter
so i'm making a combat robot in the antweight catagory and since i'm really looking into weight and budget as a concern i'd like to know if these transmiters can be used in robot combat.
http://www.sparkfun.com/commerce/product_info.php?products_id=8949
http://www.sparkfun.com/commerce/product_info.php?products_id=8946
 i know there are rules that require each contestant has to use a frequency that they are given but i don't know enough about radios to know if these can be adapted for that. these would be perfect since i have them (and they're cheep even if i didn't) and they are extremely light.
Next step: Give them vaginas
Offline Razor Concepts
  • Helpful? 53
Re: radio question. robot combat and a434 transmitters and recievers
« Reply #1 on: August 02, 2010, 06:55:35 PM »
Where are the rules? If the rules specify a frequency type, that means you must use a RC radio/receiver set.
Offline paulstreats
« Reply #2 on: August 02, 2010, 07:16:45 PM »
If you use a comercial transmitter and receiver then they will most likely have most of what you need for your robot. ie. outputs for motor controllers plus outputs for other peripherals like an additional motor controller for your spiining segment.
 The one you have linked to will require a microcontroller on both the transmitting and receiving end as well as a lot of extra programming power (remember that your robot will have the ability to cause harm to people so you will have to be extra careful in programming against bad signals causing erratic or unexpeted behaviour. a commerial transmitter and receiver are designed to only work if the signals are perfect).
 Im not too sure on the rules, but im sure that the signal bands will have to be interchangeable(you cant do this on the units you linked to). this is so 2 robots dont use the same signal band. A commercial one will have interchangeable crystals to alter the signal bands. Also they will have to be in a range where interference from other transmitters will be highly unlikely
« Last Edit: August 02, 2010, 07:48:33 PM by blackbeard »
Last post July 25, 2008, 09:52:12 PM
Last post March 27, 2009, 07:30:57 AM
by TrickyNekro
Last post July 31, 2010, 08:07:17 PM
by blackbeard
Last post July 12, 2012, 11:28:24 AM
by Mr. Ninja
