Author Topic: Problem with ISP Programmer  (Read 1325 times)
Offline w_bwrTopic starter
« on: August 04, 2010, 05:26:23 AM »
I have home made ISP Programmer for AVR. It was working fine a few days back.
but now it is giving an error message which is:
write error at the address 00000000 byte written: 0F byte read: 9F
and some times
write error at the address 00000002 byte written: 14 byte read: 97
It reades the device signature correctly.
Device Signature: ATmega162, Flash 16 kb, EEPROM: 512 bytes
plz help???
Re: Problem with ISP Programmer
« Reply #1 on: August 04, 2010, 04:51:03 PM »
Did you try this on more than one controller? (Might be your controller that went bust).
Offline madsci1016
  • Helpful? 43
« Reply #2 on: August 04, 2010, 05:09:34 PM »
is your battery dead? could be a power issue if your controller isn't powered by your programmer.
Offline Chowsfe
« Reply #3 on: August 04, 2010, 06:51:53 PM »
Maybe there is something wrong with your target board,check it
Offline amando96
« Reply #4 on: August 05, 2010, 04:18:09 AM »
The programmer is on a breadboard right? looks like it could just be a loose wire, with bad contacts, check the power lines and the programming wires.
Rorcle, 60% complete
AATV, 5% complete
« Reply #5 on: August 06, 2010, 09:23:57 PM »
Maybe, but the signature reads OK.
There is a consistent lack of bit7 and an intermittent lack of bit4 @ adr2 - sounds to me like stuck bits.
It may be the I/O lines if the signature reads out in a very different way (I don't think it does though).
« Reply #6 on: August 06, 2010, 10:45:40 PM »
The target Board is not on breadboard. Its a PCB, and was working fine a few weeks ago.
i guess that the controller is busted. I 'm out of town so can't replace it now. it 'll take some time!
« Reply #7 on: August 07, 2010, 03:03:12 AM »
Just to be sure... Remove the chip and reinsert it. Sometimes sockets develope a bad connection, especially if the two metals (socket and pin) is different, i.e. tin/gold or something similar.
Last post July 22, 2007, 11:03:24 PM
by HDL_CinC_Dragon
Last post March 09, 2008, 09:20:45 AM
Last post July 19, 2008, 10:53:52 AM
by Webbot
Last post May 29, 2008, 03:48:22 PM
by flimflap
