Author Topic: servos and motors  (Read 3014 times)
Offline gshogerTopic starter
servos and motors
« on: May 26, 2007, 06:42:05 PM »
hello, just starting to get into robotics.  i want to build my first one, but i have some questions.  i am fallowing the $50 robot tutorial, and one step has you connecting the two servos to the two wheels.  i thought servos only rotated 180 degrees, so how is this supposed to act like a wheel?
also, if im using a transmitter and a receiver for my robot, do i connect a motor directly to the receiver somehow?
Offline ed1380
Re: servos and motors
« Reply #1 on: May 26, 2007, 09:12:46 PM »
you mod the servo for continuoues rotation
the servo should plug right into the receiver
« Reply #2 on: May 26, 2007, 09:31:44 PM »
i think the next time i need to modify a servo ill film the whole thing and post it for everyone . . . for now all you get is:
http://www.societyofrobots.com/actuators_modifyservo.shtml
Offline ed1380
« Reply #3 on: May 27, 2007, 06:47:58 AM »
I found an instructable for a 325 servo. do as he says and solder teh resistors to the wires not to the pcb. I kinda messed up one servo doing that
http://www.instructables.com/id/ERRIFT3OGHEP2864PU/
« Reply #4 on: May 27, 2007, 07:08:23 AM »
ehhhh I think adding the resistor method is entirely unneccessary . . . and its harder, too ;D
