Author Topic: Problem With interfacing betwen CMucam and Atmega 32  (Read 1791 times)
Offline kupterTopic starter
« on: August 05, 2010, 12:38:24 AM »
first i want  to make robot whom can pick a tennis ball, this my design
my problem is I'm still confuse how to interface Micro and cmucam3(about handshaking betwen them and tranfer/ receive data)
    micro that i use  atmega 32
I hope there is people who can give me advice( sorry for my bad english)
Offline voyager2
  • Helpful? 6
  • Behold! The Impossible Triangle of robotics!
Re: Problem With interfacing betwen CMucam and Atmega 32
« Reply #1 on: August 05, 2010, 04:20:42 AM »
Before anyone can answer you question it would be a good idea to post your current code,pictures, etc. ;)
And it was good.
Offline amando96
« Reply #2 on: August 05, 2010, 04:24:18 AM »
I really doubt that chip can process the video from that camera, I didn't do much searching on the subject, but the atmega 32 has even less memory than a 328 right?
If you really want to process data you'll need something more powerful, like an NXP used in the Mbed, And still, not sure if it's enough!
Rorcle, 60% complete
AATV, 5% complete
Offline chelmi
« Reply #3 on: August 05, 2010, 08:03:43 AM »
The CMUCam already has a  NXP ARM processor attached to it for video processing.
« Reply #4 on: August 05, 2010, 11:00:31 AM »
in this project I use camera with type CMucam3 to take picture and process it due my programe
atmega 32 i use to command cmucam when they start to process picture ,also atmega 32 I use to take signal control from remote ( rf remote control) ,control gripper,take data from infra red sensor,also control motor dc
My question how I interface Cmucam to atmega32 ( about transfer data and clock signal)?
As I know there pin in cmu serial and ttl.. but i still confuse how to use it
this data sheet cmucam3http://www.seattlerobotics.com/CMUcam3_datasheet.pdf
« Reply #5 on: August 06, 2010, 09:38:30 AM »
there anyone can help me....urgent!!
« Reply #6 on: August 06, 2010, 10:40:09 AM »
It's all in the datasheet that you posted. Look at p.7 and make a decision on how to communicate with it.
As long as we don't know how you wanna communicate with it, it's impossible to help and besides... You'll feel a lot better if you at least try to understand what you're doing.
« Reply #7 on: August 09, 2010, 12:31:45 AM »
yes I know there way to connect with micro use Tl but I don't about Trans data or receive data, how micro know the trans  or receive data from cmucam?  and how cmucam know the receive or transmit data from micro?
Offline Bas_E
« Reply #8 on: August 09, 2010, 04:14:12 AM »
I am just a beginner myself, so I cant give you any „plug and play" answers.
What I think when reading you posts is that your talking about the software and not hardware part, right?
Everything is hooked up, but what then? Correct me if I am wrong but the communication between the components, that’s where the programming starts. That seems to be your problem?
Maybe this tutorial is a place to start? -> http://www.societyofrobots.com/microcontroller_uart_50_robot.shtml
« Reply #9 on: August 09, 2010, 10:37:18 AM »
I am just a beginner myself, so I cant give you any „plugga 32 and play" answers.
I already read this web... so i just connect Tx cmucam to Rx micro and Rx cmucam to Tx micro(ground to ground)...  how about baudrate? how about capacitor crytals I use( I use atmega 32 16Pu with max freq 16Mhz)
Last post August 31, 2008, 08:37:32 PM
by airman00
Last post May 31, 2009, 12:35:58 PM
by Swarmed
Last post March 22, 2011, 08:59:24 AM
by shyamgenious
Last post January 04, 2011, 02:12:49 AM
by averafter
