Author Topic: How to use this motor from a broken roboquad??? Please help  (Read 1278 times)
Offline amadordTopic starter
« on: August 05, 2010, 09:31:11 PM »
I am planning to use/connect to arduino duemilanove board hopefully i could control it. But have no idea . I have included a youtube video . So please check it out. thanks
Motor from a broken roboquad
« Last Edit: August 05, 2010, 11:51:02 PM by amadord »
Offline blackbeard
Re: How to use this motor from a broken roboquad??? Please help
« Reply #1 on: August 05, 2010, 11:45:27 PM »
youtube link is invalid. i'd try to reprogram the roboquad if you can though since they're really agile machines! you might want to use a few h bridge motor driver chips and of course an MCU
Next step: Give them vaginas
« Reply #2 on: August 05, 2010, 11:49:16 PM »
sorry about the broken link here it is.
« Last Edit: August 05, 2010, 11:50:43 PM by amadord »
Offline jka
« Reply #3 on: August 06, 2010, 01:50:53 AM »
Isn't it just a regular motor, that you can connect to a motor driver? I don't know what motor driver options there are for Arduino, but there might be a shield for it somewhere. The red/black wire goes tio the motor, the other two is for the switch, which you can use or not. Connect it to an input on the Arduino if you want to use it.
Offline blackbeard
« Reply #4 on: August 06, 2010, 09:36:42 AM »
There is a shield but it's overpriced like most shields. Check the thread I made about my h bridge a few posts down since I put the name of a good chip I'm using. I forget the name of it right now
