Author Topic: USB programming  (Read 2690 times)
Offline RadikenTopic starter
USB programming
« on: May 26, 2007, 11:24:04 PM »
Are any special ICs or wiring setups required to configure a board to be programmed through a USB connection?
I'm hoping to eliminate the serial connection from the board I'm designing...
The best way to get to the top is to get off your bottom.
Offline JonHylands
Re: USB programming
« Reply #1 on: May 27, 2007, 06:06:46 AM »
Look at the FT-232 chip, from FTDI. That's what I use in some of my work.
You can also get breakout boards from Sparkfun that have a USB -> TTL chip:
http://www.sparkfun.com/commerce/product_info.php?products_id=199
- Jon
Offline brainwave
Re: USB programming
« Reply #2 on: June 09, 2011, 04:02:08 AM »
u can use usbasp,its very easy, and can program pretty well.
see the usbasp site....google it
Offline brainwave
Re: USB programming
« Reply #3 on: June 13, 2011, 11:54:26 AM »
Yes, usbasp is very easy, u can definitely go for it. No special ic's. Just an atmega8 or 48.
