Author Topic: $50 Robot LED and Circuit Testing  (Read 661 times)
Offline jambotTopic starter
« on: August 10, 2010, 10:00:55 AM »
Hello,
I have a question with the $50 robot circuit - the LED does not light when the microcontroller is installed and 7 V is connected, and I have no voltage across the VCC and the PD4 pin.  Should the LED light when voltage is applied to the finished circuit before programming?
I have checked the following with my circuit:
-All connections seem to be correct when I checked with a voltmeter.
-I have 4.95 V on the microcontroller circuit past the regulator.
-The LED lights when 7V is applied directly to the LED sub-circuit without the microcontroller installed. The LED circuit between VCC and PD4 is good and has a ~ 1V drop.
- The LED is installed correctly with the positive end on the VCC side.
Do I need to wait until it is programmed to have a voltage across PD4 and VCC?
Thank you in advance!
  • Helpful? 84
Re: $50 Robot LED and Circuit Testing
« Reply #1 on: August 10, 2010, 10:36:45 AM »
Yes. The LED is controlled by the code and will light when port PD4 is set-up and written to.
You should measure about 5V on Vcc to ground without the processor.
« Reply #2 on: August 10, 2010, 05:17:29 PM »
Thanks waltr.  I am glad to know that my circuit might be all right.  I couldn't find another post that answered this clearly.
Last post March 05, 2008, 10:37:45 PM
by airman00
Last post May 29, 2009, 11:31:42 AM
by jaabot
Last post December 04, 2009, 08:17:37 AM
by waltr
Last post September 03, 2010, 08:01:42 PM
by Joker94
