Author Topic: Help with DB9 to Sabertooth 2x25  (Read 910 times)
Offline SoundDiverTopic starter
« on: August 11, 2010, 01:29:51 AM »
I'm using one of the superdroid TTL converter cables to try and interface with a Sabertooth 2x25 and not having any luck.
The cable is serial, not USB, and the TTL end of the cable has 4 wires: red, black, yellow and green.
A label affixed to the cable says: 5 volt R+ Y-, Blk ttl out, Grn ttl in.
So, I'm running the black wire to S1 on the sabertooth, and the yellow wire to 0V on the sabertooth. I have the DIP settings on the sabertooth set for simplified serial, 19200 baud. Which is all switches on except for #2 and #5 according to the docs.
Then I'm using hyperterminal to try and send a simple command to motor one.
Nothing is happening. I'm not sure if I have the wires wrong or what. There seems to be plenty of explanations for using the USB to TTL cables out there on the internet, but nothing about plain 'ol RS232.
Any help would be greatly appreciated.
Thx.
Re: Help with DB9 to Sabertooth 2x25
« Reply #1 on: August 11, 2010, 11:49:24 PM »
As it turned out, the PC I was using didn't have the COM ports enabled in the BIOS. Sheez, when did that become an option?
Last post September 28, 2008, 07:33:33 PM
by ArcMan
Last post September 27, 2010, 07:50:45 AM
by tank
Last post April 09, 2010, 09:45:41 AM
Last post November 26, 2012, 09:28:53 AM
by crchisholm
