Author Topic: Battery help needed  (Read 389 times)
Offline JedTopic starter
Battery help needed
« on: August 11, 2010, 02:42:16 PM »
i need a new battery for my new robot and i would like to know what mAh is. there is a wide varioty of mAh's and i want to know what it is, what it dose to my robot, and witch one to use.
  • Helpful? 84
Re: Battery help needed
« Reply #1 on: August 11, 2010, 02:55:20 PM »
That's mA-Hr or milliAmp-Hour and is a measure of the batteries capacity at a rated discharge rate (see battery's data sheet or specs).
In general: a 1000mA-Hr battery discharged at a constant 200mA will last 5 hour. In particular the amount of time the battery will last with a constant discharge rate is dependent on the discharge rate compared to the discharge rating, the battery temperature and the internal condition of the battery's chemistry. But the simple relationship does suffice for must work.
Last post February 28, 2007, 12:32:22 PM
by jsmoker
Last post September 09, 2007, 09:21:30 AM
by HDL_CinC_Dragon
Last post February 15, 2009, 05:44:50 AM
Last post March 22, 2010, 10:02:45 PM
by billhowl
