Author Topic: Question about multimeter  (Read 1007 times)
Offline Melcin PowellTopic starter
« on: August 12, 2010, 01:28:35 PM »
well i just recently bought a Digital MultiMeter but when i try to read resistance i get the infinite resistance sign or it bounces everywhere and then goes back down to zero. What is happening? What am i doing wrong? The leads are not touching anything other then the resistor.
Offline blackbeard
Re: Question about multimeter
« Reply #1 on: August 12, 2010, 01:32:34 PM »
well there's the usual:
-try a different resistor
-change your batteries
and if neither of those work you should probably return it.
Next step: Give them vaginas
« Reply #2 on: August 12, 2010, 02:03:59 PM »
Ya well i did that but it is till freaking out. Thanks for the advice though
  • Helpful? 86
« Reply #3 on: August 12, 2010, 02:41:22 PM »
Touch the two probes together and it should show a few readings before settling to read less than one Ohm.
If this does work then first replace the battery as Blackbeard suggested.
« Reply #4 on: August 12, 2010, 03:35:28 PM »
Well thanks waltr, but i already returned it haha. So what digital multimeter would ya'll recommend i buy now?
Offline blackbeard
« Reply #5 on: August 12, 2010, 04:26:15 PM »
if you have lots of money then get a Fluke. they're the best and they last a very long time!
« Reply #6 on: August 12, 2010, 04:44:22 PM »
Offline blackbeard
« Reply #7 on: August 12, 2010, 07:14:40 PM »
seems ok. a bit pricy for what it is though.
« Reply #8 on: August 12, 2010, 07:25:40 PM »
Well crud i sure don't want to buy anything pricey.
  • Helpful? 86
« Reply #9 on: August 12, 2010, 07:40:46 PM »
I have a couple of inexpensive DMMs that were made in Korea. One cost about $40 25 years ago and the second about $15 10 years ago. Both still work.
Any of these should be ok:
http://www.jameco.com/webapp/wcs/stores/servlet/StoreCatalogDrillDownView?langId=-1&storeId=10001&catalogId=10001&freeText=DMM&search_type=jamecoall
Maybe someone else has a suggestion of a DMM bought recently.
« Reply #10 on: August 12, 2010, 08:27:05 PM »
Make sure the multimeter can measure frequency Hz - its invaluable for measuring PWM and servo signals.
Offline tmoney68
« Reply #11 on: August 12, 2010, 09:35:15 PM »
I have an Extech model 430. It measures everything including frequency and capacitance. I don't remember what I paid,but it was quite reasonable otherwise I wouldn't have bought it.  ;D
Last post October 26, 2006, 02:27:59 PM
by polar bear6
Last post June 16, 2007, 06:17:40 PM
by ed1380
Last post August 07, 2009, 01:20:55 AM
by dsesmg
Last post August 13, 2010, 01:54:42 PM
by Melcin Powell
