Author Topic: Help with pre-processor directives  (Read 705 times)
Offline madsci1016Topic starter
  • Helpful? 43
« on: August 14, 2010, 09:50:11 AM »
I have several
#ifdef DEBUG
statements in a library file. I'd like to be able to activate those from my main c file without editing the library file. Is there a way to do that? I can't get it to work.
So the Main c file has
#define DEBUG
#include <library.h>
where library.h has all the ifdef statements in them. But this won't work, at least in the Arduino IDE. If i define DEBUG in the library header fille, then they all work.
  • Helpful? 43
Re: Help with pre-processor directives
« Reply #1 on: August 14, 2010, 04:00:08 PM »
Nevermind, i'm pretty sure I can't do what I want.
  • Helpful? 107
« Reply #2 on: August 14, 2010, 10:23:05 PM »
pre-processor directives only work at the point of generating the code.
So if the library is precompiled already then the '#defines' are  now irrelevant.
Other alternative is build two libs - one with debug, one without. Then the user can choose which to link with. Only trouble is it means 'debug everything' or 'nothing'
  • Helpful? 43
« Reply #3 on: August 15, 2010, 08:40:13 AM »
Well, the library is not pre-compiled, like the .a files of webbotlib, unless you mean that the compiler first compiles any included source files before compiling the main .c file.
Offline billhowl
  • Helpful? 32
« Reply #4 on: August 15, 2010, 09:24:27 AM »
For arduino library, you need to delete the .o file in that library then you will able to get compiler re-compile that library.
  • Helpful? 43
« Reply #5 on: August 15, 2010, 11:53:04 AM »
I'll try that Bill, but i was making changes to the library .cpp file externally using notepad++ and just hitting compile in the Arduino IDE seemed to compile with any changes made, so i think it was running a fresh compile every time instead of just linking the binary.
Last post October 10, 2007, 05:51:32 PM
by hgordon
Last post July 18, 2008, 12:24:29 PM
Last post September 19, 2009, 08:43:46 AM
by chelmi
Last post November 25, 2011, 10:35:47 AM
by joe61
