Author Topic: Distance Sensor  (Read 1056 times)
Offline jamiecTopic starter
Distance Sensor
« on: August 19, 2010, 12:06:26 PM »
Hi There
I know this subject has been quite well cover but i am after a slightly different thing, I am looking for a distance sensor that works a bit like the Sharp short distance sensors but with a much narrower bean ideally 0.5cm -> 1cm does something like that even exist ?
Also it would be good if it worked at 5v as i am using it with a arduino but i sure i can work around it if need
Any help on this would be greatly appreciated
Cheers
James
Re: Distance Sensor
« Reply #1 on: August 24, 2010, 07:51:40 PM »
There are LASER sensors, like in a Bosch LASER "measuring tape".
They're not that different from the Sharps, besides using a LASER instead of an LED (and having a much larger range).
I haven't seen just the sensors for sale and the entry level "tape" from Bosch is around $240..$250, but if you're fairly industrious, you might experiment with combining a Sharp and a LASER.
If you only need a short range, perhaps a baffle or two could be used to narrow down the beam, but less light will mean less range.
