Author Topic: small robot help-urgent  (Read 791 times)
Offline aruna1Topic starter
  • I'm an Ordinary guy
« on: August 22, 2010, 09:00:58 AM »
guys I'm making a tiny line follower robot. it is a basic line following with two transistors.I use two pager motors and rubber wheel on cassette players as wheels.my question is this robot it too fast therefor it cant respond to line accordingly. there is no motor speed control mechanism implemented.can some one please tell me how to slow this down without making a big circuit?
a transistor based pwm circuit will be great i guess.I'm posting the circuit I'm using
I'm in hurry as I'm making this for an exibition and date is getting closer
thank you
I'm Me
Re: small robot help-urgent
« Reply #1 on: August 24, 2010, 07:15:53 PM »
A diode (or more) in series with the motor(s) should help. A resistor in series with the motor(s) would work too.
Aren't you always?  ;D
Why on earth don't you start a little earlier?
« Reply #2 on: August 24, 2010, 07:18:54 PM »
well sorry for urgency.they always asked me to built them at the last moment, and with this academic load its really hard to allocaate time for robots  :(
by the way can you suggest me a small h bridge ic that contains 2 full bridges in 8 pin package?
thank you
I'm Me
Offline cyberfish
« Reply #3 on: August 25, 2010, 09:03:13 PM »
Can I get an 1 pin AND gate?
1 full bridge requires 4 inputs. 2 requires 8.
Where does power come from?
« Reply #4 on: August 26, 2010, 06:11:27 AM »
Nobody can.
2 full bridges takes (at least): 4 inputs, 4 outputs and 2 power lines.
I don't know of a 10 pin device either and since you didn't mention what voltage and current you need, I cannot point you to anything at all.
« Reply #5 on: August 26, 2010, 07:12:51 AM »
oh, i use 3.6v nimh battery and current is about 90mA per each motor
I'm Me
Offline blackbeard
« Reply #6 on: August 26, 2010, 07:24:29 AM »
Nobody can.
actually the l293d is a quad half H bridge IC in an 8 pin package. it's actually pretty good and it can control 2 motors independently
edit: DOH >.< i was thinking 16
« Last Edit: August 26, 2010, 07:25:40 AM by blackbeard »
Next step: Give them vaginas
« Reply #7 on: August 26, 2010, 07:25:37 AM »
Nobody can.
nope it has 14 pins
I'm Me
Offline knossos
  • Helpful? 13
« Reply #8 on: September 11, 2010, 01:40:38 AM »
Well, a simple way would be smaller wheels.  Not sure how small your line follower is, but a great idea for small wheels can be found on some of the beetle bots.  Use the motor shaft itself as the wheel, you can even put some heat shrink on it for more traction.  Also changing the angle of the motor will change speed of the robot: the closer the motors are to being parallel to the ground, the faster the robot goes.
Hope this doesn't come too late.  I'm curious to hear what solution you used.
« Last Edit: September 11, 2010, 01:41:58 AM by knossos »
"Never regret thy fall,
— Oscar Wilde
Last post August 24, 2007, 02:04:03 AM
by awally88
Last post September 22, 2007, 08:51:36 AM
by HDL_CinC_Dragon
Last post January 28, 2008, 07:28:31 PM
by airman00
Last post November 12, 2008, 05:31:21 PM
by Commanderbob
