Author Topic: TI 14 pin microcontroller or a Sharp 20 pin  (Read 1110 times)
Offline notgivenTopic starter
« on: August 23, 2010, 03:25:58 PM »
Anyone know how i can connect TI 14 pin microcontroller or a Sharp 20 pin microcontroller to a standard type A USB?
 I found them and so have no schematics.
Re: TI 14 pin microcontroller or a Sharp 20 pin
« Reply #1 on: August 23, 2010, 04:34:40 PM »
Give us the part number. There are hundreds of parts that fit the description you give.
But, there is basically a 99% chance that those are not USB chips, as USB is very new, and the vast majority of such chips designed to handle USB are surface mount.
« Reply #2 on: August 23, 2010, 04:42:17 PM »
SHARP:8946E3004
TI:SN74LS107AN
« Reply #3 on: August 23, 2010, 05:04:56 PM »
i thought all i had to do was connect the right pins to the four usb contacts to allow me to talk to the microcontroller
  • Helpful? 84
« Reply #4 on: August 23, 2010, 05:41:15 PM »
Well first the TI chip is NOT even a microcontroller! It is a Dual J-K Flip-Flops With Clear.
http://focus.ti.com/docs/prod/folders/print/sn74ls107a.html
The Sharp chip is unknown.
Did you try googling either of these ICs?
Did you google USB and look at the specs?
Did you go to the various microcontroller manufacturer's web sites and search on USB?
Any of these google searches would get you lots of info on USB including which microcontrollers could be connected to USB.
Last post February 21, 2008, 03:18:08 PM
by javafiend
Last post July 30, 2009, 04:06:51 PM
by SmAsH
Last post September 01, 2008, 01:20:17 PM
Last post February 25, 2011, 04:52:37 PM
by djdinop
