Author Topic: Where to start with microcontollers ?  (Read 823 times)
Offline ashourTopic starter
« on: August 25, 2010, 03:56:04 AM »
I'd like to work with microcontollers to be able to enhance my robots , but i don't understand how to start?
Also is there a sort of a microcontroller that can be programmed directly from a computer maybe via a usb cable and not having to buy its programmer? , because all programmers are beyond my budget.
This a link for where i buy electronic components please would someone tell about a convenient microcontroller for a beginner?
http://ram-e-shop.com/test11/index.php?cPath=21_23
What are the microcontollers kits? i've seen them on the electronics shop website , whats does they do and do i need one of them?
thanks
Offline Joker94
  • Helpful? 26
Re: Where to start with microcontollers ?
« Reply #1 on: August 25, 2010, 04:23:35 AM »
Well the first possibility if you want to build it yourself is the $50 robot micro controller. it is really cheap to build and a programmer is cheap if you have a serial port, but they are quite old and there are not many left especially on laptops. therefore you may need to invest in a programmer but the way to look at it is it is a one time buy and you can get one that will last a long time for $20. of course there are more expensive ones out there that can do more and are better quality but you can get some nice ones to start with that are cheap.
the $50 robot is a fantastic starting point for robotics, how many people on this forum started with hibby robotics.
Do you want to build a microcontroller from scratch or want a ready made microcontroller?
Offline billhowl
  • Helpful? 32
« Reply #2 on: August 25, 2010, 09:39:05 AM »
You can use this ATMEGA8L-8PI to build it yourself with the SoR $50 robot.
You can also bulid your own Programmer like this
http://diy4fun.blogspot.com/2009/01/simple-serial-programmer-for-avr.html]Simple Serial Programmer for AVR[/url] using some common component ie. transistors, Zener diode and resistors.
Offline GearMotion
  • Helpful? 24
« Reply #3 on: August 26, 2010, 08:39:26 AM »
You can see some step-by-step description of the 6-pin version of this circuit here: http://circuitgizmos.com/wordpress/?p=452
Offline blackbeard
« Reply #4 on: August 27, 2010, 11:42:35 AM »
like others have said avr is the way to go if you want to be able to stick a program on a chip and profit. if you want a more lego like approach (no soldering, simple programing and the ability to reuse parts) then the arduino is another way to go.
Next step: Give them vaginas
Offline collegerobotics
« Reply #5 on: August 27, 2010, 08:51:31 PM »
Go with arduino man. The best for beginners. If you know a bit of C++, then run through some of the tutorials on the arduino.cc website and you should quickly get a grasp of it and be able to apply it to your project.
Last post April 17, 2007, 08:15:52 AM
Last post June 07, 2008, 11:46:18 PM
by Private reid2
Last post May 27, 2008, 04:30:55 PM
by izaktj
Last post June 02, 2008, 04:36:48 PM
by alovon
