Author Topic: ir sensors  (Read 608 times)
Offline ManojkumarsmksTopic starter
ir sensors
« on: August 30, 2010, 12:22:06 AM »
i have built a sensors as given in the following link
http://www.societyofrobots.com/schematics_infraredemitdet.shtml
i have not connected  lm358 ckt,
i want the output of T1(as in first diagram) to be given to MUC 8051 but  the output is analog one..
how do i get the digital output???
to give the output of L1 and T1 to comparator, the output measures around 1.8v!!
please help... please
Offline ballbreaker
Re: ir sensors
« Reply #1 on: August 30, 2010, 01:35:34 AM »
am not an expert and maybe am wrong but i think in order to get a digital signal you are gonna need to connect a uf ceramic capacitor to filter the analog signal to digital
For Those About To Rock, We Salute You!
  • Helpful? 84
Re: ir sensors
« Reply #2 on: August 30, 2010, 09:43:30 AM »
Try thinking a a digital signal as really being a analog signal that is either almost 0V (a low) or almost at Vcc (5V) (a high). So there are a few ways to get the output from the photo-transistor to be either a low or high logic levels.
1- addition amplification that swings the full voltage range, 0 to 5V and what the light from the LED reflects from, black or white but not in the greys.
2- Use a comparator IC, the LM339 is a common one, to threshold the input voltage to a low or high logic level.
3- Use a logic gate that has a Schmidt trigger input like a 7414 IC (this is the generic part number so a real part will have a prefix and some letter between the 74 and the 14).
Re: ir sensors
« Reply #3 on: August 30, 2010, 11:56:46 AM »
hey thanks..will tryout it by 2moro and let u know guys..
thanks a lot...never though ppl will reply!!!
thank u..
Re: ir sensors
« Reply #4 on: August 30, 2010, 05:46:15 PM »
There's no LM358 in the first schematic, which is a purely analog circuit and will be best suited for an A/D-input.
No matter how much gain you add, there will always be a range where you have an analog transition.
As waltr mentioned, digital is merely analog driven to the extremes.
The op-amp circuit is also best suited for an A/D-input, but could be changed relatively easy (move the feedback resistor) to give a digital output, just change the negative feedback to be a positive feedback an adjust the value for a sensible shift point. That way the output signal will be either "1" or "0".
If you want to stay with transistors, let the photo transistor control a 2-transistor Schmitt-trigger  and you will get approximately the same functionality.
Last post December 24, 2008, 11:40:10 AM
by bryan922
Last post March 28, 2012, 07:01:07 AM
Last post November 29, 2012, 12:22:15 PM
by murtagh024
Last post February 17, 2013, 11:36:06 PM
by jwatte
