Author Topic: $50 Robot - Question about ATMEGA8-16PU Availability  (Read 1086 times)
Offline jp1390Topic starter
« on: August 30, 2010, 11:53:13 AM »
Hi, so I just started getting all the parts together for this but the only problem is that the ATMEGA8-16PU MCU is not available anywhere or has a really long lead time. Is there an alternative to this part that I could use that wont change the setup of this robot, around the same price?
Thank you,
JP
Offline Conscripted
  • Helpful? 10
Re: $50 Robot - Question about ATMEGA8-16PU Availability
« Reply #1 on: August 30, 2010, 12:41:34 PM »
The atmega 168 has the same pinout as the ATMEGA 8. No need to change the hardware at all. You will just need to change the software a little. There is already a tutorial to tell you how.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=ATMEGA168V-10PU-ND
Conscripted
« Reply #2 on: August 30, 2010, 01:03:01 PM »
Conscripted
Awesome! Exactly what I was looking for haha. Any idea on where this tutorial is? Makes my life much easier!
JP
EDIT: nvm it's in the $50 outline.
« Last Edit: August 30, 2010, 01:51:12 PM by jp1390 »
Offline lowprofyl
« Reply #3 on: September 14, 2010, 01:55:56 PM »
ATMEGA8-16PU... couldnt find it anywhere.
will the ATMEGA8L-8PU work the same.. just a little slower?
Offline Conscripted
  • Helpful? 10
« Reply #4 on: September 14, 2010, 02:34:45 PM »
It has less memory but otherwise should work the same.
  • Helpful? 107
« Reply #5 on: September 14, 2010, 04:45:34 PM »
Or get the ATMega328P. Same pinouts but 32k of program memory versus 8k on the ATMega8, or 16k on the ATMega168
Last post January 11, 2008, 04:46:16 PM
Last post March 16, 2009, 01:01:07 PM
by SmAsH
Last post August 10, 2009, 01:04:07 AM
by Razor Concepts
Last post September 29, 2009, 05:45:46 AM
by Conscripted
