Author Topic: Bootloader for Sparkfun 9DOF Razor IMU  (Read 2170 times)
Offline InvictaTopic starter
« on: August 31, 2010, 01:50:15 PM »
Hi
The Sparkfun 9DOF Razor IMU as sold uses the Arduino bootloader for uploading code. Now that Webbot's Project Designer supports the Razor's MCU (ATmega328) can I use the Axon2 bootloader, FBoot GUI, written by catalinene33 to upload my Razor firmware to the Razor? I would rather not try this cold as the Razor is expensive and hard to source in the UK.
  • Helpful? 107
Re: Bootloader for Sparkfun 9DOF Razor IMU
« Reply #1 on: August 31, 2010, 02:57:05 PM »
@Admin - got a view?
Offline madsci1016
  • Helpful? 43
« Reply #2 on: August 31, 2010, 05:08:07 PM »
Are you asking if you can flash the Fboot bootloader onto the Atmega; or just flat out use the GUI to upload programs?
If you wanted to replace the Arduino bootloader you need a hardware programmer to flash the new bootloader. If you have the hardware programmer, why not use that to upload your code every time anyway?
Or am I missing something. (completely possible)
« Reply #3 on: August 31, 2010, 05:50:48 PM »
If what you meant was overwriting the Arduino bootloader with the FBOOT bootloader using a hardware programmer, here is the .hex:
http://www.societyofrobots.com/robotforum/index.php?topic=5932.msg45154#msg45154
Last post September 02, 2010, 07:19:05 PM
by Webbot
Last post January 08, 2011, 03:57:33 PM
by Ryltar
Last post November 25, 2011, 08:57:59 PM
by Webbot
Last post November 08, 2011, 07:28:49 PM
by Webbot
