Author Topic: rant: arduino protoshields >.<  (Read 640 times)
« on: September 01, 2010, 08:08:09 AM »
so i got a protoshield strictly for prototyping purposes for my combat robot (testing and programming). the damn thing is riddled with useless traces! i can't fit more then 1 ic because they decided to make it like a single section on a breadboard rather then a collection of holes which i could use for my own space conscious arrangement. why are arduino shields so useless? why didn't i just print my own circuit board like i wanted to in the first place! i have the crystal for the atmega chip and i'm just about ready to snip off my motors and do just that.
Next step: Give them vaginas
Re: rant: arduino protoshields >.<
« Reply #1 on: September 01, 2010, 08:39:07 AM »
Get a seeeduino and make your own protosheilds using normL protoboard  ;D
« Reply #2 on: September 01, 2010, 08:42:51 AM »
i've been looking at that but i like the idea of popping out my chip and sticking it in a project. that and i'm cheep. in the future i'll solder a jack in a piece of protoboard and work off that.
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
« Reply #3 on: September 01, 2010, 07:49:33 PM »
I am working on a shield for Arduino with the beginner in robotics in mind. So far I have ordered Rev. 1 of the board that includes:
  • 6 servo connectors, powered from the battery, digital pins 8-13
  • 6 sensor connectors, powered from regulated 5V, all analog pins
  • hardware serial connector
  • built in h-bridge, SN754410, digital pins 4-7, uses Timer0 for PWM
  • reserved space for a mini breadboard so users can experiment
  • external interrupt pins available for encoders
While waiting for the boards to arrive, I added for Rev.2 of the board:
  • filtering capacitors near the servo and sensor connectors
  • prototyping area under the mini breadboard, some people might want to use that instead of the breadboard
  • all pins doubled under the breadboard
Why have I done this? Because the Roboduino does not have the possibility to add shields on top and does not have a built in h-bridge. Many people just buy an Arduino then have issues building a proper shield for robots, I was waiting for someone to do it, but I got tired of waiting.
Here is a picture of the first revision and underneath the second revision, still work in progress:
« Reply #4 on: September 02, 2010, 06:58:48 PM »
Watch out for acid traps (you have a couple).
When this one has matured, why not go for a SMD proto module, I'm sure a lot of people would like that, considering the ever shrinking amount of thru-hole components.
Last post November 19, 2006, 01:39:22 PM
by JonHylands
Last post April 19, 2007, 01:40:50 PM
by ed1380
Last post September 10, 2010, 06:59:22 AM
by voyager2
Last post October 14, 2010, 06:47:15 PM
by Gertlex
