Author Topic: 50$robot construction sequence question  (Read 974 times)
Offline rabadswompeTopic starter
« on: September 01, 2010, 11:13:59 AM »
Hi all,
Well, all my parts are here. Re-reading the tutorial, specifically about servo miodification, I saw that to "center the servo" i need a microcontroler to input the .hex file
I'm illiterate in robotics, just starting out. what I read above tells me that i need to get the 50$ robot microcontroller make BEFORE modifiing the servos for the heels....right ? i just want to make sure i do it right and that i don't need to buy something else...again.
oh, in case this info helps, I'll be using the AVRISP mkII programmer. I also have yet to download the AVR studio4, pony prog and all that as stated in the tutorial.
Thanks for responding
Offline richiereynolds
Re: 50$robot construction sequence question
« Reply #1 on: September 01, 2010, 11:22:32 AM »
yep, that's right, make the microcontroller first.
« Reply #2 on: September 01, 2010, 01:36:16 PM »
thanks! ;D I had planned the "blindly follow the steps" given in the tutorial.... so off soldering I go!
Re: 50$robot programmer question this time
« Reply #3 on: September 01, 2010, 05:07:43 PM »
Hello Again.
Just finished downloading and all.
There is a link to a post on here about opening the programmer to switch the 6 pin to a 10 pin. Is that necessary ??? I'.m making the 50$ robot with AT mega8
Offline Hawaii00000
« Reply #4 on: September 01, 2010, 07:22:20 PM »
I'm not sure what you mean about 6 pin and 10pin, but you have to have either an ATmega8, ATmega168, or ATmega328. The ATmega168 and 328 are the same as the ATmega8, just more powerful.
-Paul Dirac
Its Hawaii Five-O. Get it?
Offline Metal Slug 2
  • Helpful? 11
« Reply #5 on: September 01, 2010, 07:57:08 PM »
For the AVRISPmkII programmer you can just use the 6-pin ribbon cable as it is.  Somewhere on these forums is a post where instructions are given on how to setup your $50 robot for use with the AVRISPmkII programmer.
Also, you don't actually need PonyProg if you have the AVRISPmkII; PonyProg is only needed if you have the Serial programmer.
« Reply #6 on: September 02, 2010, 10:13:50 AM »
Thanks Metalslug... there is indeed a post on that and it took quite a lot of reading to find a clear indication. I says it's just a minor adjustment to make the pins to 6 instead of 10...there is also a good pdf graph that shows it clearly.
Offline GearMotion
  • Helpful? 24
« Reply #7 on: September 03, 2010, 10:58:06 AM »
Also take a look here for build instructions that highlight using the 6-pin ISP connector.
http://circuitgizmos.com/wordpress/?p=471
Last post August 12, 2007, 08:54:00 AM
Last post October 05, 2008, 08:47:43 PM
Last post February 08, 2010, 12:30:58 PM
by snooza
Last post January 18, 2012, 12:40:44 PM
by iisous
