Author Topic: compining geard dc motors with servos ic  (Read 1698 times)
Offline ballbreakerTopic starter
« on: September 02, 2010, 12:05:48 PM »
i didn't know where it fit so i placed it here
 because i dont have a microcontoroler atm (am planning on getting an axon for Christmas)
i can't modify some servos i have to operate with remote control so am asking
if i take the ic board in my servo and put it in a geared dc motor will it work or will i have to consider the voltage required for the board and the motor to be the same?
also what else should i be worried about?
 thank you
For Those About To Rock, We Salute You!
Re: compining geard dc motors with servos ic
« Reply #1 on: September 02, 2010, 02:30:21 PM »
You can buy pre-modified servos if youd like?
Or you can use the other modification method which replaces the pot with two 2.2k resistors?
« Reply #2 on: September 02, 2010, 02:58:43 PM »
yes. You also need to consider both the voltage and the current draw of the motor.
Any reason why you might want to do this?
« Reply #3 on: September 02, 2010, 03:44:40 PM »
i cant buy anything online atm and they dont sell unmodified servos anywhere near me.
can you explain this method with the 2.2k resistors?
« Reply #4 on: September 02, 2010, 03:49:32 PM »
« Reply #5 on: September 02, 2010, 03:56:39 PM »
wow thanks thats alot simpler than the other method
