Author Topic: Alternative motor ideas  (Read 1044 times)
Offline SamcatTopic starter
« on: September 03, 2010, 03:07:24 PM »
Greetings.
I am planning a small walker robot.  The action of the legs is giving me fits.  I want to have independent control of the x and y-axis of the legs.  This cannot be done with independent servos or linear actuator, they are simply too large.
I came up with a solution, but i would like your feedback on it.
Here is a bad ASCII image of it.
        Perm Mag     Electromag    Perm Mag
            _______________________________
_______|___{}    [|||||||||||]  {}________|_____
|o        |     {}    [|||||||||||]  {}             |      o| fixed points for string routing
|                NS                        SN                     |
|                                o                                  |
|o                                \                               o|
  string/fishing wire             \
                                        \ robot leg
                            motion        \
The 'motor' would all be encased in something very thin, on the order of a straw.  When controlling the electromagnet, it will cause the permanent magnets to pull the robot leg left/right, or up/down.  This would be 12 separate motors (6 legs), but packaging would be greatly reduced and by using string for 'tendons' they could be strategically hidden..
In theory, you can move a leg in any path you want just be controlling the electromagnet voltage (analog output).  Or use fixed voltages for just forward and back.
Like I said, I have not worked on it enough to know what is best sizing (length/width or straw), heat considerations, etc.  Also need to decide how best to get the AC/DC power right to control both directions.
Has anyone else done any work like this?
Offline blackbeard
Re: Alternative motor ideas
« Reply #1 on: September 03, 2010, 03:30:44 PM »
give it a shot. it'll probably use less power then a servo.
Next step: Give them vaginas
« Reply #2 on: September 03, 2010, 05:52:38 PM »
I am waiting new magnets to show up (got the wrong type).  I don't really have the right equipment to test efficiencies and find an optimal setup.
Just fishing for ideas while I am waiting.
Offline voyager2
  • Helpful? 6
  • Behold! The Impossible Triangle of robotics!
« Reply #3 on: September 03, 2010, 06:32:08 PM »
How big are your magnets, and where did you get them?
And it was good.
« Reply #4 on: September 03, 2010, 08:39:04 PM »
http://www.kjmagnetics.com/proddetail.asp?prod=R412
Neodynium Ring Magnet N42
1/4" OD (should fit nicely inside a McDonald's straw)
1/16" ID (small enough to tie a string)
1/8" thick (needs to be large enough to not flip inside the chamber)
Ordered today.  Should get in a few days.
Offline voyager2
  • Helpful? 6
« Reply #5 on: September 03, 2010, 10:38:48 PM »
No I mean the electro magnets
And it was good.
« Reply #6 on: September 03, 2010, 11:04:24 PM »
 ;D
I just made my own.
I started with a simple finishing nail, added some plastic washers I cutout (about 1/4" round), and wound magnet wire around it until it was the same height as the washers.  I made a few of them with longer spans (from 3/8" to 3/4") and larger/smaller nails.
I did order some 1008 low carbon steel wire to use as the metal core to eliminate residual magnetism.
(how do you post pics?  I can upload a few pictures of my horrible wrap job.)
Offline voyager2
  • Helpful? 6
« Reply #7 on: September 03, 2010, 11:33:26 PM »
To post pics:
[img][/img]Put the link to your pic in between the img bits
The picture has to be on the internet already, just upload it with something like photobucket.com
And it was good.
« Reply #8 on: September 06, 2010, 04:08:04 PM »
Did you consider Muscle Wire?
If you have room elsewhere for servos/motors, you can use cable (like on a bicycle gear/brake) to transfer the movement.
« Reply #9 on: September 07, 2010, 09:04:45 AM »
Here is all of them
The small ones detail
The large ones detail
Fit into a straw
Obviously, I still need to cut the ends off the nails.  But the nails have too much magnetic memory.  I am afraid it will hurt performance of using them like an AC motor.  I have ordered some low carbon steel wire to use instead.
I will investigate Muscle wire for the future.  Figuring out the controls and cost will really complicate it.  If the electromagnets don't work, I will take a closer look.  For now, I want to get something off the ground.
« Last Edit: September 07, 2010, 03:51:51 PM by Samcat »
« Reply #10 on: September 07, 2010, 09:47:19 AM »
fixed?
« Last Edit: September 07, 2010, 03:52:18 PM by Samcat »
Last post September 11, 2007, 08:25:57 AM
Last post January 24, 2008, 12:14:53 PM
by Del
Last post March 13, 2010, 09:57:17 AM
by rockrobotics
Last post August 29, 2012, 07:50:12 AM
by ankitbansal
