Author Topic: Bluetooth unable to connect to computer  (Read 1789 times)
Offline Ji Jing MengTopic starter
« on: September 08, 2010, 11:22:46 AM »
I am encountering some problems connecting my ATmega8 via bluetooth module (KC Wirefree SKKCA-21) to my computer. Whenever I try to connect to a COM port, the message "The device you selected does not have a serial port service running" appears. I can't seem to figure what the problem exactly is as I have initialized UART and solved all errors and warnings.
My Source Code:
#include "SoR_Utils.h"
int main(void)
char keypress;
uartInit();  // initialize the UART (serial port)
uartSetBaudRate(115200);// set the baud rate of the UART for our debug/reporting output
configure_ports();
rprintfInit(uartSendByte);
LED_on();
while (1)
keypress=uartGetByte();
if (keypress!=-1)
if (keypress == 'r')
rprintf("Connection Loaded 100%");
return 0;
Any solutions or ideas?? Your help will be greatly appreciated.
« Last Edit: September 08, 2010, 11:26:33 AM by Ji Jing Meng »
Last post August 09, 2009, 09:02:43 AM
by Novice1
Last post September 02, 2009, 02:41:48 PM
Last post November 04, 2010, 09:29:09 AM
Last post September 02, 2012, 02:01:54 AM
by ironheartbj18
