Author Topic: Sabertooth Connecting Ports  (Read 1196 times)
Offline moltrex84Topic starter
« on: September 10, 2010, 08:18:47 AM »
Hello,
I have a sabertooh and I'm following the tank control example to be tested in a axon2 ...
I tried yesterday and it was not a successful, I used UART 0 and connect transmitter in S1 and receiver in S2, both ground connected. I used a simple serial connection … I need help.
Which configuration should I use for this.
1-   Which Port in the microcontroller ???  UART 0 ??? What baud rate if need it ??
2-   Which configuration in the Motor drive ??? Simple serilazed ???
3-   Which Port in the Sabertooth S1 and S2 or only S1 ???
Help will be gladly accepted … I will post a cool video of what I’m doing if I get this solve …
Thanks,
  • Helpful? 111
Re: Sabertooth Connecting Ports
« Reply #1 on: September 10, 2010, 03:27:30 PM »
You can make life easier for yourself by using my Project Designer http://www.webbot.org.uk/iPoint/37.page
This lets you configure the device and shows how to connect it and what DIP switch settings need to be done
Offline madsci1016
  • Helpful? 43
« Reply #2 on: September 10, 2010, 04:27:26 PM »
And in case you haven't used it before....
Axon 2, Webbotlib and Project Designer Tutorial
« Reply #3 on: September 17, 2010, 06:44:10 AM »
Did you get it to work?
(I also recommend using WebbotLib - makes things much easier)
You can use any UART port you want. The baud rate must match that defined in the Sabertooth datasheet.
« Reply #4 on: September 19, 2010, 10:33:11 PM »
Hello I was able to make it work ... the problem was that I was using a wrong Buad rate with the Sabertooth 2x50Amp.
And the UART that It was in the example if I'm not wrong it was used also with the GPS and there was a conflict ...
But it works ... thanks ...
