Author Topic: My Fire-Bot  (Read 1216 times)
Offline robotiksistemTopic starter
My Fire-Bot
« on: September 11, 2010, 04:25:46 PM »
Fire-Bot is an autonomous mobile robot project, that can find the candles and blow them out.
Fire-Bot is controlled by PIC16F877A. It has two DC motors and a servo motor. The DC motors are controlled with L293D integrated motor driver by using PWM of PIC16F877A.
To detect the candles Fire-Bot uses its Sharp GP2Y0A21YK0F sensor and to determine whether or not it is close enough to the candle the robot has also a TSOP1738 IR sensor. At the beginning Fire-Bot measures the room's temperature with DS1821 temperature sensor placed on the fan and takes this temperature as the reference. When Fire-Bot catched the candle, it measures temperature and turns on the fan in order to blow the candle out. After the candles is blowed out, the fan is turned off.
you can watch its video
http://www.robotiksistem.com/robotproject.html
Offline voyager2
  • Helpful? 6
  • Behold! The Impossible Triangle of robotics!
Re: My Fire-Bot
« Reply #1 on: September 11, 2010, 06:44:43 PM »
I can see one problem with it, the fan is likely to blow more oxygen (O2) on the candle, therefore fueling it.
When you blow out, CO2 accompanies the O2 staving the flame of O2
And it was good.
Re: My Fire-Bot
« Reply #2 on: September 12, 2010, 02:45:43 AM »
I also know that, but here the topic is to perform the mission as simple as possible. I've used just a fan that i got at home, to blow the candle out. In order to blow out the candle without any problems, the fan is accerlerated and then made slower continuously.
« Last Edit: September 12, 2010, 02:49:31 AM by robotiksistem »
Offline voyager2
  • Helpful? 6
Re: My Fire-Bot
« Reply #3 on: September 12, 2010, 03:27:16 AM »
A short, fast burst should do it (like you said).
Working reliably is the main thing!
And it was good.
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
Re: My Fire-Bot
« Reply #4 on: September 12, 2010, 06:52:45 PM »
A motor from an El chepo hair blower should be more than fine...
But you should check that is indeed an el chepo with a DC motor...
Or else you are going to have much much trouble driving it....
Cheers!
Last post September 18, 2008, 05:39:39 PM
by SeagullOne
Last post March 26, 2011, 12:06:04 PM
Last post December 06, 2011, 04:54:54 AM
by rbtying
Last post April 01, 2012, 01:07:50 AM
by Fr0stAngel
