Author Topic: A very basic question on 'C' variables  (Read 894 times)
Offline InvictaTopic starter
« on: September 13, 2010, 06:05:56 PM »
If you do not assign a default value to say an integer or float Global variable what does the compiler assume the value to be? I have not been able to find any 'C' reference document that says anything about what the compiler assumes!
Code snippet:
// Global Variables for Euler angles
float roll;  // No default value assignment
void Compass_Heading()
  float cos_roll;   // Local variable
  float sin_roll;   // Local variable
  cos_roll = cos(roll);   // I assume that for the first iteration roll is = 0.0
  sin_roll = sin(roll);   // I assume that for the first iteration roll is = 0.0
//Remainder of function goes here
Thanks for your help
« Last Edit: September 13, 2010, 06:07:59 PM by Invicta »
Offline knossos
  • Helpful? 13
Re: A very basic question on 'C' variables
« Reply #1 on: September 13, 2010, 06:22:00 PM »
The number will not be zero unless it is explicitly declared as zero.  For proper programming you need to either explicitly declare a starting value or read in an initial value before using the variable.  Anything else and you are asking for problems.
"Never regret thy fall,
— Oscar Wilde
Offline madsci1016
  • Helpful? 43
« Reply #2 on: September 13, 2010, 08:23:49 PM »
Yes and No. The C standard will guarantee all global variables will be initialized as 0 if not initialized as something else.
The same guarantee does not extend to variables initialized inside functions however.
Offline madsci1016
  • Helpful? 43
« Reply #3 on: September 13, 2010, 08:26:50 PM »
Here you go.
http://www.nongnu.org/avr-libc/user-manual/FAQ.html#faq_varinit
« Reply #4 on: September 13, 2010, 08:34:59 PM »
While the C standard might state that, it would be good to check with whatever software you are using to find the exact answer. I wrongly assumed that all globals were initialized to zero when working with MSP430s, and it did give me a bit of trouble.
« Reply #5 on: September 14, 2010, 10:24:47 AM »
Thanks Guys
Fantastic, exactly the answers I was looking for. With your guidance I also found this interesting discussion that mirrors your views:
http://www.embeddedrelated.com/usenet/embedded/show/28174-1.php
Once again
Thank you.     p.s. madsci1016 +1 helpful
« Last Edit: September 14, 2010, 11:01:48 AM by Invicta »
Offline knossos
  • Helpful? 13
« Reply #6 on: September 14, 2010, 04:09:51 PM »
I have come across times where I assumed the global would get initialized and ended up with headaches later.  Always better to be safe than sorry and declare it.
— Oscar Wilde
  • Helpful? 107
« Reply #7 on: September 14, 2010, 04:43:27 PM »
Using the gcc compiler (WinAVR) then all global variables are set to 0 before calling your main.
Some folk have said that you should initialise variables explicitly to avoid confusion. ie:
int myVar = 0;
In an 'ideal' world this is true - because you can read the code and know that the start value is 0.
However: doing this will actually make your 'program' bigger - ie it will need more flash memory !
Why?
Well all un-initialised variables are just lumped together into sequential bytes of RAM (called the BSS). The C compiler then inserts a 'for' loop to zap all of these to zero before calling your main since it knows how many there are and how big they are.
The compiler also lumps together all the variables that you give an initial value to. It has no choice but to store this list of initial values in program (flash) memory. It then has a similar 'for' loop, before your main, to copy all of these initial values out of your program memory and into the RAM.
So if you initialise global variables to a specific value then the variable will take up not only runtime RAM space but also the same amount of flash/program space to store the initial value.
Of course if you are using a large AVR then this may not be a problem.
Offline madsci1016
  • Helpful? 43
« Reply #8 on: September 14, 2010, 05:09:00 PM »
Man, that's so much more clear then the FAQ section I linked. Now I understand it better!
Offline knossos
  • Helpful? 13
« Reply #9 on: September 14, 2010, 06:36:01 PM »
Very well said Webbot.  My experience is primarily computer programming.  The amount of memory used to declare one value (even a larger data structure) is typically insignificant when dealing with computers, particularly compared to potential programming pitfalls and portability of code.  I have to get back into the mindset of optimizing my code size. :)
— Oscar Wilde
Last post June 18, 2008, 10:29:16 AM
by krich
Last post July 24, 2008, 05:37:17 AM
by zack
Last post December 24, 2009, 02:15:38 PM
by waltr
Last post March 11, 2010, 05:11:43 PM
by rockrobotics
