Author Topic: Door safety interlock  (Read 547 times)
Offline minivanTopic starter
« on: September 15, 2010, 03:30:21 PM »
Hello,
I need help with the following question. Any suggestion would be very much appreciated.
I want to have a safety interlock for a safety enclosure. The enclosure door cannot be open when the power is on. I have a power supply 208VAC, 20 Amp. I also have 24VDC outputs from a PLC.
Thank you.
  • Helpful? 84
Re: Door safety interlock
« Reply #1 on: September 15, 2010, 06:15:26 PM »
Use a solenoid to latch the door from the inside, or block the movement of the door latching mechanism. 208VAC or 24VDC solenoids are readily available.
« Reply #2 on: September 15, 2010, 08:51:13 PM »
Thanks, Waltr. How about this one http://www.mcmaster.com/#linear-solenoids/=8v5cq4 to latch the door from the outside? Thank you very much.
  • Helpful? 84
« Reply #3 on: September 16, 2010, 07:31:36 AM »
I don't know anything about what your cabinet is like so can not make a recommendation. Can you get that one to work for you?
Last post April 24, 2007, 06:16:14 PM
Last post January 07, 2008, 06:00:43 PM
by Rebelgium
Last post March 01, 2009, 04:54:20 PM
by Razor Concepts
Last post March 16, 2012, 09:38:40 PM
