Author Topic: 50$robot resistor value... wich one is it ?????  (Read 722 times)
Offline rabadswompeTopic starter
« on: September 17, 2010, 06:45:16 AM »
 I can't figure the value of the resistor that is supposed to be soldered-in next to the led.
The parts list specifies 2 different resistors (in packs of 5) 1.62 k ohm and  340 ohm BUt the instructables steps don't mention the value...just to bend the metal pins 90°, solder and not cut them off. Yes... it took just that to stop me in my tracks :(
at the same time, the resitors mounted just behind the photoresistors... what value are they ????
Also, I did order from digikey and got my resistors but none are the same colour as the on in the pic... values are as asked though.
please help
« Last Edit: September 17, 2010, 07:00:25 AM by rabadswompe »
Re: 50$robot resistor value... wich one is it ?????
« Reply #1 on: September 17, 2010, 07:05:02 AM »
ok... i found my info on this thread :
http://www.societyofrobots.com/robotforum/index.php?topic=4737.0
the 340 ohm goes next to the LED and the 1.62 k ohm go to the photoresistors.   right?????
are resistors polarized ? It think they're not but still, more prudent to ask.
only one worry... the colour coding. CAN resistors from diff makers/sellers have same value but diff colour ?
Learning as I go
Yann
« Last Edit: September 17, 2010, 07:15:33 AM by rabadswompe »
Offline GearMotion
  • Helpful? 24
« Reply #2 on: September 17, 2010, 07:31:04 AM »
Resistors are not polarized.
Differences in the color code may be because your resistor has fewer or more stripes. For now just write down the colors of a resistor and the value (taken from a package) in your notes just to keep from being confused. It might be simple enough to note that of the two resistors only the 340 has a yellow stripe, for instance. Later, though, you should learn the resistor color code. There are hundreds of web sites that will help if you google for "resistor color code".
« Last Edit: September 17, 2010, 07:33:30 AM by GearMotion »
« Reply #3 on: September 17, 2010, 07:49:10 AM »
super! Thanks GearMotion!
i must say tha the patience and helpfulness of the members of this forum is examplery and really keep newbees like myself at work and learning.
Offline GearMotion
  • Helpful? 24
« Reply #4 on: September 17, 2010, 10:01:46 AM »
Always glad to help!
Last post April 23, 2007, 12:55:47 PM
by hazzer123
Last post September 17, 2010, 01:30:44 PM
by Metal Slug 2
Last post March 14, 2009, 04:08:37 AM
by superchiku
Last post February 17, 2011, 09:30:50 PM
