Hi,An FPGA (Field Programmable Logic Array) is more or less a GAL/PAL/PEEL on steroids. You can build a µcontroller in an FPGA (if you're sharp), but if you're confused about them, I think you'd be better off using a ready made controller.What are your reasons for wanting an FPGA over a µcontroller?
I heavily suggest you read both of those links, I think there may be more to FPGA's than what was originally thought by the Robot communities. Also, I'm an Electrical Engineer major, so I'm looking for the real deal...not just a quick and dirty Arduino project with some stolen roborealm code.
Quote from: ahack3r on September 21, 2010, 09:41:59 PMI heavily suggest you read both of those links, I think there may be more to FPGA's than what was originally thought by the Robot communities. Also, I'm an Electrical Engineer major, so I'm looking for the real deal...not just a quick and dirty Arduino project with some stolen roborealm code.No one here put down FPGAs as a possible solution, we are just trying to make the point that if the goal of your project is to make a robot, there are easier ways. If you want your project to be about using FPGA to make a robot, have at it. But you are going to be spend more time on the FPGA part and less on the robot. I'm a degree'd Electrical Engineering (under)graduate, Soeren & waltr are seasoned EE experts. I took grad level classes in VHDL and computer architecture and designed a single cycle core architecture in FPGAs as a term project; it's no picnic.
Since you are in school for EE this could be a good opportunity to use a PLD (any type of programmable logic array).They are getting more and more powerful and are slowly replacing processors in many types of embedded systems. They are not going away.
Started by Admin Electronics
Started by lanamor Electronics
Started by Indiana_Geoff Electronics
