Author Topic: Temperature Sensor Arduino Program with LM335  (Read 9177 times)
Offline galannthegreatTopic starter
« on: September 22, 2010, 09:21:41 PM »
I am currently working on a data logging project right now with an Arduino and I have some code working, but I want to make it a bit more accurate. I am wondering if people know of any ways I can do that.
Here is my code:
#define SENSOR 0 // select the input pin for
                 // the LM335A temperature sensor
float val = 0; // variable used to store the value
               // coming from the sensor
float val2 = 0;
float celcius = 0;
void setup()
  Serial.begin(9600); // open the serial port to send
                      // data back to the computer at
                      // 9600 baud
void loop()
  val = analogRead(SENSOR); // read value from the sensor
  val2 = val/2;
  celcius = val2 - 274;
  Serial.println(celcius); // print the value to
                           // the serial port
  delay(1000); // wait 1 second between each
               // each reading
Thanks, Kurt.
Kurt
Offline rbtying
  • Helpful? 31
Re: Temperature Sensor Arduino Program with LM335
« Reply #1 on: September 22, 2010, 10:35:01 PM »
What sensor are you using?  Also, what do you want to make a bit more accurate?  Please clarify
Sorry, I didn't read the title.
The LM335 has an output of 1mv/K
Your code uses analogRead, which uses a 10-bit ADC to convert the 0-5v into 0-1024 bits.
As such, you need to start by converting the reading back into volts:
val *= 0.0048828125;
Then, divide the voltage by 100 to get 10mV resolution.  At this point, you should cast to a shorter variable to avoid floating-point operations
int deg = val / 100;
Lastly, subtract 273.15 degrees to get degrees Celcius from Kelvin:
deg -= 273;
In summary:
deg = (int)(analogRead(SENSOR)*0.0048828125/100)-273;
Make sense?
« Last Edit: September 22, 2010, 10:49:08 PM by rbtying »
« Reply #2 on: September 23, 2010, 12:12:24 AM »
Thank you very much for that :), it helped me figure out what I wanted to do.
Here is the new code: (I didn't follow exactly what you did but I did the same sort of thing)
float val2 = 0;
float deg = 0;
float celcius = 0;
void setup()
                      // 9600 baud
void loop()
  val2 = val * 0.00489; // take SENSOR value and multiply it by 4.89mV
                        // and store value to val2
  deg = val2 * 100; // multiply by 100 to get degrees in K
  celcius = deg - 273.15; // subtract absolute zero to get degrees celcius
                           // the serial port
               // each reading
P.S. It also turns out that I should precisely calibrate the sensor to get more accurate results, but it is doing what I want. YAY!
Kurt
