Author Topic: Solder/solder temp  (Read 641 times)
Offline FleetTopic starter
Solder/solder temp
« on: September 23, 2010, 11:52:51 PM »
I am building the 50$-robot. What diameter should the solder for the controller have, and at what temperature should the soldering iron have? (I want to use lead-free solder)
/Fleet
Offline cyberfish
Re: Solder/solder temp
« Reply #1 on: September 24, 2010, 12:23:49 AM »
1mm is pretty standard. Just make sure you get electrical solder not plumbing solder (plumbing solder has very corrosive flux).
For lead-free you'll want close to 400C.
If you are a beginner, though, leaded solder is quite a bit easier to use. FYI, the switch to lead-free is for the environment, not safety, if that's what you are worrying about. All critical devices are still made with leaded solder for reliability (no one knows how reliable lead-free solder is, yet, because it hasn't been around for that long).
If you are doing a big production run, lead-free could make sense if you are environmentally conscious, or want to sell your product in Europe. For prototyping and hobbyist work, the environmental impact is negligible, and leaded solder is a lot easier to use (flows better, melts at lower temperature, etc). But it's up to you.
Offline galannthegreat
« Reply #2 on: September 24, 2010, 01:33:05 AM »
That's a little hot, try 600 F or 325 C. I found going over 350 C I started to burn boards after a couple of seconds of contact... just a technicians tip.
Kurt
Last post February 24, 2010, 01:26:19 PM
by Hertz32
Last post January 11, 2009, 12:10:59 PM
by HDL_CinC_Dragon
solder
Started by g44 Electronics
Last post April 04, 2010, 09:45:45 PM
Last post May 09, 2010, 06:12:52 AM
by corrado33
