Author Topic: Will this work on new 50 buck robot?  (Read 1480 times)
Offline NOOBinDistressTopic starter
« on: June 03, 2007, 08:36:57 AM »
I am considering buying HITEC HS-81 HS 81 HS81 MICRO SERVO SERVOS JR Z instead of HS 311 servos for my second robot.I was wandering if these servos would work and if they would work on the updated part of the tutorial where you need a third servo? Please help thanks.
Re: Will this work on new 50 buck robot?
« Reply #1 on: June 03, 2007, 09:39:12 AM »
The Hitec HS-81 will not work for the robot wheels cause the datasheet says its not modifiable for 360 degrees. It will work for the scanning sharp IR since it should not be modified for that.
If you use a different servo, you may need to tweak the signal pulse width a bit.
For example in my code, if you see
servo_right(41);
you might need to change it to say
servo_right(45);
or something like that until the servos do what you want.
Last post June 01, 2007, 08:35:34 PM
by NOOBinDistress
Last post March 05, 2008, 12:31:49 AM
by Mcrich113
Last post February 23, 2010, 10:38:31 AM
by pomprocker
Last post January 16, 2011, 01:45:42 AM
by Hermes Chen
