Author Topic: PING))) Ultrasonic Sensor  (Read 1587 times)
Offline Yr0gErGTopic starter
« on: September 30, 2010, 02:28:43 AM »
Hi I would like to know certain applications for this particular sensor. I'm currently thinking of using this sensor in conjunction with a p18f4520 PIC microcontroller to detect a white block of dimensions 100mmX100mmX40mm at distances of 150mm, 350mm and 550mm. Will this sensor be able to perform such a task and to what accuracy? Is there anything to take note of when installing/mounting this sensor? Can i put this sensor close to a surface, like placing it a few cm over a robot base?
Offline garrettg84
  • Helpful? 8
Re: PING))) Ultrasonic Sensor
« Reply #1 on: October 01, 2010, 02:07:43 PM »
Sounds like it should work, atleast up to the 350mm. The 550 mm you may experience a bit of jitter though. I just mocked up that setup with my ultrasonic sensor (and AVR micro) and a chunk of wood approx 100mm cubed at home. It was good for the 150mm distance, the 350mm distance and the 550mm distance it started some jitter.
-garrett
Offline knossos
  • Helpful? 13
« Reply #2 on: October 01, 2010, 04:22:26 PM »
Remember the signal spreads out in a cone shape (like this < ).  If you are too close to a surface you can get inaccurate readings.  A simple solution is to tilt the sensor upwards so that the bottom of the cone is approx parrallel to the surface.  (Like this /_  ).  You shouldn't have to tilt it much ( No  more than about 1/2 the beamwidth).
"Never regret thy fall,
— Oscar Wilde
Offline MtnbikerET
« Reply #3 on: October 02, 2010, 11:14:45 PM »
Just make sure its on the front of your robot, and facing perfectly parallel to the object. Perhaps an IR rangefinder would be better for your needs.
p.s: don't try to make your own ultrasonic sensor. I tried it, and utterly failed.
Last post February 16, 2009, 09:42:06 PM
by Keppnertj
Last post September 06, 2008, 06:28:38 AM
by Ro-Bot-X
Last post October 02, 2010, 05:44:32 AM
by Webbot
Last post February 05, 2012, 01:12:46 AM
by omkar
